do springs settle in?
Old Apr 9, 2008 | 03:49 PM
popular's Avatar
popular
pushrod
Default do springs settle in?
For some reason, most notibly one of my rear springs is sitting particularly higer than the other? I fitted brand new avo springs which lower about -35mm I believe but it is sitting almost standard height on one side and quite alot lower on the other? I did one side at a time; have I done something wrong or will they settle in onver a few days? Cheers
Old Apr 9, 2008 | 03:50 PM
AlexF's Avatar
AlexF
yup!
Some cars also like you to tighten up blots that go through bushes with the weight of the car acting on them - so they are not loaded/twisted.
alex
Old Apr 9, 2008 | 03:52 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
sounds like you have either installed one of them inccorectly or you have been supplied with 2 different springs?
got any pics of the wheel off to see the assembly?
have you checked the serial numbers/codes on the springs/box match?
Old Apr 9, 2008 | 03:58 PM
BM08's Avatar
BM08
pics of either side??
Old Apr 9, 2008 | 04:07 PM
popular's Avatar
popular
pushrod
springs looked the same next to each other so I assume they were the same; installed the rubber bung and jacked the car up and fitted bolts back into damper; appears to be sitting all good but on one spring, 3 of the coils are tightly compressed and on the high side, only 2 are tightly compressed?
High side
low side
Old Apr 9, 2008 | 04:16 PM
Paulo P's Avatar
Paulo P
That driveway looks crooked, is it like that on the flat too?
Old Apr 9, 2008 | 04:34 PM
popular's Avatar
popular
pushrod
yeah it is still uneven on the flat
Old Apr 9, 2008 | 04:36 PM
C4llyT's Avatar
C4llyT
Suppose swapping them doesn't take much effort, narrow it down to spring or install error.
Old Apr 9, 2008 | 04:46 PM
S1rst's Avatar
S1rst
I assume you have taken it for a good spin just to see if it settles back down again? They often take a couple of miles to settle to normal ride height, and then may still get slightly lower after a while.
Id do as C4llyT said above and swap them round and see what happens.
Old Apr 9, 2008 | 04:52 PM
popular's Avatar
popular
pushrod
yeah reckon I will swap them on weekend
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 24, 2015 01:36 PM
L1AM_RS
Sep 23, 2015 03:27 PM
