afr gauge readings..?
09-04-2008, 12:54 PM
hello all..
i have just fitted an lc1 from graham goode in my saff and am now after finding out what readings i should be lookin for ie when to worry... any help please..
thanks
09-04-2008, 01:01 PM
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
If it reads Lambda 1.0 when you're on boost - worry
Ideally it needs to be in the 0.7's on boost
09-04-2008, 01:09 PM
11.8:1 on boost if its in the 12s or any later get it sorted!
09-04-2008, 01:10 PM
hi.. ticking over its not a stable reading but hovers around 11.9 ish and low boost looking like going to mid 12 but still not stable .. ???
09-04-2008, 01:20 PM
Doesn't sound too bad, get it checked out by someone who knows what they are doing though!
09-04-2008, 02:16 PM
Live long and prosper!!
Quote:
Originally Posted by
gibbo frst
What gauge? i use a G3 with the dial
The wiring on these NEED to be perfect!! 12's on low boost is no good needs to be in the 10/11's on high boost to be safe at max RPM late 10 imo
What car what set up ?
Paul
09-04-2008, 02:23 PM
12.5:1 on max load my cossie use to do
09-04-2008, 02:30 PM
Did Someone Mention TUV
Bobby Singh
that seems a tad lean. What sort of boost was that figure at?
09-04-2008, 02:45 PM
check the reading you get on the laptop software against the gauge if it isn't an XD gauge, as ground offsets can have a big effect.
09-04-2008, 03:38 PM
A little knowledge is a dangerous thing on this subject!!!
Becareful!
09-04-2008, 06:23 PM
Rick
correct!! if unsure check it against a Mot machine should be close if all is ok
on tickover mine is between 14 and 15 (closedloop)
Paul
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Chas
05-10-2015 07:13 PM
IainRS1700T
25-09-2015 06:44 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
