What Fuel hose for in-car?
What is the best braided fuel hose to run in-car?
I have heard that some cheaper brands allow fuel fumes through?
teflon inner I here is the way to go, also heard of CPE Inner but not sure what that is??
Any help appreciated
Dave
Dave
Goodridge 811 sounds popular,
Does'nt the pro gold from Think need to use there own fittings?
Also who is the most reasonable supplier
I used this lined hose for fuel incar :
Which used the fittings with olives on the right side of this picture :
This hose for anywhere else or oil lines, this uses the normal fittings :
Got a quote on Earls today which wasnt to bad.
Anyone delt with them before?
I use think for everything, the pro gold fittings were given to me though and I was later informed that they were VERY expensive so I've used a alloy fitting which is black and has a blue nut on it that Think supplied me.
Just speak to them and tell them what your after and they will be able to help you out.
The lined hose isn't Earls or Aeroquip, its a hydraulic style hose they do and its MUCH cheaper than the branded stuff, no idea on what it was called but they told introduced me to it.
Russ Payne
25-09-2015 08:29 PM
