cossie wont select gears
02-04-2008, 08:41 PM
3 door resto in progress
when i put the gear nothing happens want you reckon the onli thing iv duno iz change the sump gasket. cheers charlie
02-04-2008, 08:44 PM
Passion for Fords!
check nobody has stolen your wheels,and left it on bricks
02-04-2008, 08:48 PM
02-04-2008, 08:50 PM
Quote:
Originally Posted by
JTECHSAFF
lol
JTECHSAFF
02-04-2008, 09:50 PM
02-04-2008, 09:52 PM
rs_cos
2 wd
what did you have off when you did you sump
02-04-2008, 09:53 PM
crossmember and steering rack but i put the jack under the box 2 support the lump
02-04-2008, 09:56 PM
what does the clutch feel like when you press it and have you tried pulling the peddle up and the try it
02-04-2008, 09:59 PM
dnt feel the same as it use 2
02-04-2008, 10:00 PM
try pulling it up and let me know
02-04-2008, 10:01 PM
i can turn the prop shaft when itz in gear and runnin
02-04-2008, 10:02 PM
sounds like the clutch ratchet has over ratcheted
As said above.. try lifting the pedal upwards from its static position until it clicks, then press it down a couple of times and see how it is then.
Lee
iv tryed pullin it up and it dnt work still
02-04-2008, 10:06 PM
you may need to take the cable of and make sure the ratchet is ok
02-04-2008, 10:08 PM
ok how do i know if the racket iz ok or not
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
The Youth.
30-09-2015 09:59 PM
