Lambda Sensor Thread Size
Old Apr 1, 2008 | 06:41 PM
Ryan's Avatar
Ryan
Default Lambda Sensor Thread Size
Anyone know what it is?
Want to get my turbo housing redrilled as the lambda hole has been welded up, so need to let the machine shop know what size to drill it too.
cheers
Old Apr 1, 2008 | 06:45 PM
Jay,'s Avatar
Jay,
Sponsor
usually 18mm x1.5 mm pitch
you have got sumat on the way to you
Old Apr 1, 2008 | 07:14 PM
Wazzzer's Avatar
Wazzzer
Ryan I've got a boss and a blanking nut here if you want it?
Old Apr 1, 2008 | 07:30 PM
foreigneRS's Avatar
foreigneRS
Testing the future
there's 2 sizes - i believe that those fitted to the turbo are the smaller of the 2 (12 x 1.25mm, not 18mm that the wideband normally are) but you should check this as i am not 100% sure
Old Apr 1, 2008 | 09:03 PM
Ryan's Avatar
Ryan
cheers lads.
can anyone shed some light? will be fitting the usual sensor for closed loop
Old Apr 1, 2008 | 09:06 PM
KSA-Cossie's Avatar
KSA-Cossie
If ford sensor then 12x1.25,others are 18mm.
Old Apr 1, 2008 | 09:32 PM
GARETH T's Avatar
GARETH T
what sensor are you using?
Old Apr 1, 2008 | 10:52 PM
Ryan's Avatar
Ryan
havent got one yet, but will need to work with l8/p8/s8
Old Apr 1, 2008 | 11:02 PM
Ryan's Avatar
Ryan
yeah im pretty sure wil be a usual bosch item like stu sells for his closed loop kits.
Old Apr 1, 2008 | 11:05 PM
The DIVA's Avatar
The DIVA
Bosch LS 02
M18x1.5
Old Apr 1, 2008 | 11:10 PM
Ryan's Avatar
Ryan
cheer rob, will tell the guys when i take it down for drilling tommorrow.
then the turbo can go back on
should be ready to start at the weekend
Old Apr 1, 2008 | 11:35 PM
JonnyBravo's Avatar
JonnyBravo
I've just picked up a turbo shield tonight, did you still need the brackets off one ?
Old Apr 2, 2008 | 07:31 AM
Jay,'s Avatar
Jay,
Sponsor
fuckin told u nancy boy
Old Apr 2, 2008 | 07:41 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The narrow band is M12, the wide band is M18, check my website for prices . Properly machined items with recess to aid location etc .
http://www.randbmotorsport.co.uk/sho...?ProductID=342
http://www.randbmotorsport.co.uk/sho...?ProductID=343
Old Apr 2, 2008 | 07:44 AM
Dan's Avatar
Dan
Originally Posted by The Diva
Bosch LS 02
M18x1.5
Spot on! Identical to mine
Old Apr 2, 2008 | 01:57 PM
Although the narrow band is available in 18mm also!!
Old Apr 2, 2008 | 01:58 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Whats the difference between narrow band and wide band?
Old Apr 2, 2008 | 02:19 PM
Ryan's Avatar
Ryan
just thought i would check something, and indeed i was right, where the lambda boss, are situated on the escort exhaust housing the sensor would foul on the head due to the 2wd manifold and the angle it put the housing at. bugger.
oh well least i found that out before i had the housing drilled.
guess its gotta be a boss welded on the downpipe then, will get the car running and then drive the car somewhere to have the boss welded on rather than start taking bits off again
Old Apr 2, 2008 | 02:25 PM
Dan's Avatar
Dan
That's how mine was done Ryan, make sure you leave any heatshield's and strut brace's etc off to make it easier for them!
Old Apr 2, 2008 | 02:42 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Fit 18mm, that way you can run either a narrowband or a wideband in it.
Old Apr 2, 2008 | 10:18 PM
Wazzzer's Avatar
Wazzzer
see that boss I'm sending you will come in handy now
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Mk5brown
Sep 9, 2015 12:52 PM
