removing cossie rear calipers help!
whats best way to remove the rear calipers from a 2wd cossie
ie how do you release the handbrake cable?? just bloody well cant get mine off....
Resident Wrestling Legend
under the passenger side there is the adjuster to slacken the handbrake cable
slacken this off all the way
then remove the little circlip that holds the cable in place at the calioper ends
then use a scewdriver to lever the cable furthe out of the outer sheathimg
yu can now bend the cable around enough to get the caliper hook end off the caliper lever for the mechanism
its a bit of a shite job but its the only way unles you cut through the cable
09-10-2015 07:38 PM
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
