question about rear beams - camber??
I understand with the modded rear beams that camber and toe can be adjusted with use of rose joints, but does the 6 degree modification deal with camber increasing as the rear end squats? (Sorry cant seem to find an answer on the search query).
Therefore is there less chance of wheel spin due to tyres staying more square to the road surface or am I wrong in thinking this?
yes, as the wheel forms far less of an arc as it travells, exactly the same way it combats bump steer, as as the wheel moved uowards on the old beam, it gives a huge change in toe and camber.
Not having seen one of these beams, I would be interested how much change there is.
Obvioulsy ANY semi trailing arm as opposed to trailing arm will induce camber changes, but would be interested yo read of owners(modded beams) views.
Football Cwazy
Basically, the pick up points are moved, so that the movement of the trailing arm is different to standard, you can kind of tell from the picture, that when the arms pivot, they move upwards rather than inwards...if you get me ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
![](http://img.photobucket.com/albums/v215/bud-weis/23042007038.jpg)
Didn't Mike_R have some measurements of the changes on his Moonstone Blue Sapphire thread - if it's still on here that is - used to be in one of the other forums I think
Rear bumpsteer:
* * * * *Bump
60mm - 0.030" toe in
50mm - 0.023" toe in
40mm - 0.015" toe in
30mm - 0.009" toe in
20mm - 0.005" toe in
10mm - 0.003" toe in
0.0mm - 0.000" toe in
* * * * *Droop
10mm - 0.001" toe out
20mm - 0.002" toe out
30mm - 0.003" toe out
Rear bumpsteer:
* * * * *Bump
* * * * *Droop
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
