Help Connecting PS3 Wirelessly?
Old Mar 29, 2008 | 12:09 AM
mark_J's Avatar
mark_J
Default Help Connecting PS3 Wirelessly?
Hi all,
Trying to get my PS3 hooked upto my Sky broadband wirelessly, I put in what I think is my WPA (no errors or anything came back) but when it tests for the connection, it comes back as failed?
Old Mar 29, 2008 | 12:56 AM
Andy_R's Avatar
Andy_R
I had a similar problem which was solved by resetting the SKY(Netgear) router.
This is done simply by inserting a pin in hole at the back of the router. Holding it in untill the router resets(im sure the lights change, all go out).
Worth a try if you havent already!
Old Mar 29, 2008 | 10:41 AM
DanRSturbo's Avatar
DanRSturbo
Does any other hardware connect wirelessly ? If so then it's a simple setting issue. Doing the above will completely wipe everything off the router so you'll need to re-access it and re-do the wireless settings etc
Old Mar 29, 2008 | 11:03 AM
FletchCossie's Avatar
FletchCossie
Did you use the WPA key from the bottom of the router?? (Just making sure lol) Try unplugging the router and plugging back in.
Old Mar 29, 2008 | 02:54 PM
mark_J's Avatar
mark_J
Thanks for the replies guys.
I don't think I have anything else to connect to the PS3 wirelessly so can't answer that one.
The WPA I used was the one from the card Sky gave (same as bottom of router)
When during the setup period should I reset the router?
Thanks again!
Old Mar 29, 2008 | 03:25 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i had this problem...only way i solved it was to connect using a wire first, then go wireless.
Old Mar 29, 2008 | 04:03 PM
DanRSturbo's Avatar
DanRSturbo
Connect it to a pc first, then set the router up and give it your own wireless settings and try that
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
