anti lag...
anti lag...
who on here runs anti lag?and which turbo do yo use? im building up a big spec yb soon and want to see what parts i shall be needing. i want it to run around 500-550 bhp and must be able to cope with anti lag. to start i may even leave it at 450-480 bhp and see how it goes fom there.
also how do screamer pipes work?
B1mbo
you dont have to have a marham shafted turbo to run anti lag but it is deffinately better to have one as you wouldnt want to run anti lag for long without one. as for 500 -550 bhp a rollerball bearing marham shafted t4 is a good one to go for speak to mike rainbird or a gt30 but that dont have marham shaft. and screamer pipes are just a pipe coming off the external wastegate, no reall advantage just sounds good in some peoples opinion
Shizzle My Nizzle
As for anti lag, its great, sounds good, looks good. But id say only get it if you really think you need it, i,e if u track the car, 1/4mile it etc. If its just on there for fun then, you will probalby end up using it more than you "should" and will need a new turbo much quicker.
if its for fast road driving, watch you dont make old biddies jump and fall over when you drive buy. (it has been known)
B1mbo
peoand also sound like a bag of nails in other peoples opinion i saw a screamer on a jap crap motor, he spent a fortune on it, just sounded like the engine was knackered and the exhaust had a rusty hole in it!!
you dont have to have a marham shafted turbo to run anti lag ..........
oh you do, mine lasted 3 months on a standard shaft, ended up like a banana, turbo seized solid......
it will have to be roller bearing t4 as i dot like the way the standard t4 comes on boost so late.. yh its going to be a msd anti lag so more than likley mild. i will be using it for 1/4 mile eventuly.
o right so meaning it will last longer basically.. i ant to run 1/4 mile runs also, but also want to use it on the roads (not often tho) even tho its ilegal
the Mar -M will take around 200 deg more than a std shaft so better than std, I think a std shaft is good for abou 900 deg for so many hours i forget how long.
M K- your GT, how long you use it for at a time, Im pretty sure it wont last long on a track day style drive. Glad its keeping well on the road so far
R5FORD- you wont have any lag so it wont matter where the boost usually comes in, if driving in correct gears then progress should be Mmmmm swift!boost to limiter everytime- I cant wait to use mine on a run
155lee
24-10-2015 11:11 AM
