Nos on a cos - Need tuners here please
Someone on aother site:
"Mcpikie, i could quite happily run a cossie at 500bhp on gas with a set of yellow injectors, as the nitrous kit provides the fuel it needs anyway.
The pump would need to be up to flowing enough though obviously.
FRP wouldnt need changing it would remain the same."
Erm, i'm kinda of the opinion this is bullshit, your advice lads??
Jeebus
No, nitrous is just compressed oxygen basically (with some nitrogen in it!) And it burns a lot more efficiently than normal air. But as it is only oxygen it still needs a propellant to make it burn! The point is that it has its own fuel injector that comes on with the nitrous, therefore no extra fuelling is required from the normal injectors.
Or if you are Sean Bicknell, you can go one step futher and map the nitrous fuelling into the normal injectors!
as per stu... the extra fuel required is supplied by the nitrous kit, it pumps in nitrous AND fuel
very simple. you just T off of the std fuel feed hose and this runs to the nitrous pulsoid, which when activated will open and allow the extra fuel required to flow thru into the crossfire injector (via a jet which is just a "thing" with a hole in it, depending on what size hole you use depends on how much fuel can flow)
but getting a std cossie up to 500bhp with JUST nitrous... erm... very doubtfull
the feed will come from the same place that it would on a single/normal system it just runs into a distribution block which seperates it to each injector
so you have 1 pulsoid, 1 jet and then a single line going into a distribution block with 5 holes on it (4 o/p one 1 i/p) and each output receives 1/4 of the total extra fuel.
direct port isnt really THAT much extra complication, you just have to drill a lot more holes and get some distribution blocks (glorified T peices)
nitrous is SO simple its unreal!
theyre not big on the direct port things, i'd say about 3mm holes? (going from memory)
steve/rapid1 tried direct port a while back (switched back to normal in the end) and it all fitted fine on his std plenum... (4inj)
cos I got a WRC 8 injector manifold that I am only gonna use 4 injectors in, just wondering if I could machine some blocks up with 2 jets in to sit in the spare injector holes to keep it all tidy
not really... id have thought it'd be easier just to drill 8 little holes in a std plenum to be honest! lol
altho IIRC steves were in the inlet manifold itself (now i think about it) as its closer to the head therefore better. i think they were in the runners (that what they called? the individual tubes)
Rod
if you use 4 crossfire injectors thats not quite the same as the "conventional" setup, which uses 8 normal/little ones.
i woulda thought 4 Xfires would work better tho
as for the AFR check, you'd need non-std equipment to do that as the nitrous content in the exhaust gas confuses your normal lambda readings... makes it read rich when it aint. i beleive you can buy special (and VERY expensive) equipment which means you can get round this tho...
a few rolling roads have blown up nosed engines that way.... thinking its rich when its not so leaning it off till it goes pop
just a little unrelated bit of info for you there... lol
Originally Posted by RWD_cossie_wil
do they spray stright into the bellmouths inside the plenum rod? And how much are you looking at for a kit/set-up like that?
Yes!!
Its a standard wizard of Nos Streetblaster system with a Direct port Nitrous upgrade, which included bigger pipes etc. Despite what is claimed a sustained 100bhp is absolutely max with a Single shot system.
Complete with a progressive controller i expect cost is in the 900/1000 region. Allows upto a 200bhp shot capability . Only tried 130 shot so far , but will use much more when we return to Brunters in the new year.
I take it you would need to run a separate fuel pump for direct port?
Direct port NOS is usually chosen when you are injecting a large amount of Nitrous, say 150BHP upwards.
So you throw in your 150BHP NOS jets, but there is no way to get the fuel jets correct as the standard cossie fuel system has a rising fuel pressure.
For example at 0 bar boost we are running say 3 bar fuel pressure. But at 2 bar boost we are running 5 bar fuel pressure. We can't change the delivery pressure of the NOS as the fuel pressure rises, so we end up with a rich mixture at full boost or a lean mixture at anything less than full boost (this is why standard kits are normally rich on boost as they are compensating for off boost mixture).
It isn't to much of a problem on say a 50BHP single fogger setup, but the problem gets explanentially worse as you raise the BHP of NOS that you want to inject.
Brom and I have gone for a seperate fuel pump and seperate regulator for the NOS. The other beauty of this system is you can very acuratly adjust the NOS / Fuel ratio by tweaking the fuel pressure of the NOS fuel system.
Sean..
i disagree with you there sean (but if im wrong sum1 please correct me as i'm curious to know)
the reason the fuel pressure changes is becasue the pressure being forced upon the std injector is high, so we increase the pressure of the fuel to equal out the difference. that way the pressure differential at the ijector tip always stays constant nomatter what boost/vacuum we're running.
the same thing would be occuring to the nitrous fuel jet, it is having boost thrown against it, so we would also want the fuel pressure increased to compensate. if we did not then we would be running less extra fuel at high boost than not on high boost, hence making the system LEANER as the boost increases.
also if youre using a seperate regulator for yours, then the fuelpressure is also increasing in this seperate fuel system (that is ofcourse if it is a rising rate reg) so youve got the same thing you get on the std system
My car is checked by Mark Shead who has all the correct equipment on the RR its no different & my RR man does loads of Nitrous cars with no probs.
It sounds as if you have listened to Trev who is altra cautious on such matters to protect his system from the 'Nova' boys & runs his systems very rich. Believe me 200mph finds out the correctly set-up Nitrous systems .
I am assuming that nitrous in these instances is only used at full throttle, so boost levels should be fairly constant? hence negating the need for rising rate fuel pressure?
nitrous IS only used on full throttle...
but boost stil varies at full throttle depending on lag and mapping etc.
rod, i dont doubt your install, im not picking holes, but i stand by what i said. on "normal" afr gear it WILL read rich, the laws of chemistry/physics/whatever dictate that! the sensor/reader needs to be able to adjust for this
also saying 200mph finds out if its set up correctly is a bit of a dodgy statement to make... why does a car doing 200mph show if a nitrous setup is correct or not? it could still be running rich/lean and pull 200mph...
On a large turbo car, between gears for example, when you floor the throttle in the next gear the engine isn't instantly on full boost.
Say you are throwing in 150BHP of NOS and you have set the mixture to be correct at full bosst, say 2.2bar. As soon as you hit full throttle after the gear change and the turbo is rising from a vacuum and climbing through boost for a few seconds before reaching full boost you are only throwing in enough fuel for say 50bhp of NOS but all the time throwing in the full 150BHP of NOS.
As i said this problem gets explanentially worse as you increase the amount of NOS you want to run. On a 50 - 75BHP single fogger type system, it would not really be an issue.
Sean..
Sean..
Sean..
Lets just say that my system works Sean & ive not adopted your method.
I agree with what you say Jim, but the boost pressure is also pushing back on the NOS jet by the same degree, but we are not increasing the NOS delivery pressure to compensate.
And no the regulator on the NOS fuel line is not a rising rate regulator it is static, but still adjustable to make fine tweeks.
Sean..
Sean..
sean, good answer, explains it perfectly for me
do you in that case sean run a non-rising rate reg for the nitrous fuel system?
