12v Eps Power supply ?
RWD Racer
Slowly getting a corsa power column fitted and now got to the stage of powering it up.
Looking to use a handy power feed n found these units under the dash.
Know nowt about them apart from the 1st one comes from the battery then branches out to the radio n amp ec?
So will it be ok if I break into one of those + feeds and run the main + eps feed to power the steering motor?
Can't see much else usable under the dash that looks man enough cable wise, or is it better to run a dedicated live?
RWD Racer
tbh I guess a seperate feed is the safest bet after all
As for the motor I couldn't say but these pics might give an idea of motor size?
http://img.photobucket.com/albums/07.../260z/col1.jpg
http://img.photobucket.com/albums/07...260z/coll4.jpg
What sort of fuse size type and size would you recommend?
07-10-2015 12:56 PM
