things that i don't mind
getting wet
skinning my knuckles
muddy trainers
stabbed in the little finger by something sharp
getting more wet
what i do mind however is spending 2 and a half hours trying to undo one fucking nut
whoever decided that they were going to put the lower arb drop link nut behind the crossmember so that not only can you just about fit a spanner there, there is too much other shit in the way to be able to turn it is a cunt
so if they are reading this, i'm coming for your bollocks with a blender
and no, i still haven't undone the fucker
muddy trainers
getting more wet
changing the waterpump on my bmw a few weeks back, 4 x 10mm nuts to undo, not enough toom to get a socket on a ratchet into them so had to use a shitty short 10mm spanner, took fucking ages turning them, holding the spanner with 2 fingers, trying to get it back on the nut, dropping it, going under the car, getting the spanner, trying again to get it on the nut with two fingers as my fat hand wouldn't fit down
Horrible fucking job. If only i had a nice long 10mm spanner or one of them ratchet spanners. Alas. Its done now but it took fucking ages.
It Wasnt Me!
Or the guy that made the bolts just long enough on the rear anti roll bar on an escort mk3/4 so that they were a headache to take out without lots of swear words
i had a ratchet spanner
but there is not enough space to use it when you have to use a pair of mole grips to hold the other end of the bolt that is connected to the drop link
i have pictures and, when i get to the other house i shall load them up and you can all see what the fuss was about
ended up using a dremell to cut the top of the nut off but even then, there isn't enough space to correctly weild it so it took 12 discs to cut enough of the nut off to make it budge
JoeyBoyden
14
15-08-2015 09:51 PM
