BD10 Cams
Old Oct 20, 2004 | 07:01 AM
Jo's Avatar
Jo
Default BD10 Cams
can BD10's be used with standard escort cossie vernier pulleys?
Old Oct 20, 2004 | 07:03 AM
alan rainbow's Avatar
alan rainbow
YES
Old Oct 20, 2004 | 07:07 AM
Jo's Avatar
Jo
great, thanks
what difference do they make to the engine, higher revs?
Old Oct 20, 2004 | 08:34 AM
cossymad's Avatar
cossymad
I put BD10's in mine. I gained 16bhp.
I also noticed at between 3500-6000 more power and it pulls harder.
One thing though bit of a flat spot under 2000 though.....not really a problem for me as I never go that low
Old Oct 20, 2004 | 08:38 AM
Jo's Avatar
Jo
didyou use your standard vernier pulleys?
what does a set of bd10's cost?
Old Oct 20, 2004 | 08:41 AM
cossymad's Avatar
cossymad
Yep standard pulley's
Old Oct 20, 2004 | 08:46 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
They're normally GIVEN away by some tuners, as they're SHIT . Chris can get away with it to some extent, as he has a turbo that (believe it or not ), is smaller than IMAs cock . If I owned a T3/4 car, I wouldn't fit them if you PAID me to . Stick with the standard ones or a BD14 inlet, or K2 on both sides .
Old Oct 20, 2004 | 08:49 AM
Jo's Avatar
Jo
hmm, getting confused here now
Old Oct 20, 2004 | 08:51 AM
cossymad's Avatar
cossymad
Although Mikes opinions are generally true, it is impossible for anyone to take a word he says seriously, from a man who still tucks his jumpers into his chino's like he did when he was a rocker in the 60's.
He is right about the size of IMA's cock though
Oh and Jo the prices are the same for all profiles
Old Oct 20, 2004 | 08:54 AM
Jo's Avatar
Jo
LOL , cheers guys
Old Oct 20, 2004 | 09:02 AM
Disabled Account's Avatar
Disabled Account
Jo,
IMO Standard cams are fine for up to 380 - 400 BHP.
I have tried BD10's and was VERY dissapointed - mainly due to the lack of mid range torque. This is in context of a Paul Bailey built engine to this spec:
Standard compression ratio, 200 'O' ringed block
Big valve, flowed head
Light Blue injectors
T38 (hybrid 360° bearing) rinning 26 PSI
2 WD exhaust manifold/ Maxnex system
Back to back tests at Interpro's rolling road......and YES - the BD10's were dialed in correctly on verniers/adjusted a couple of times too.
Standard cams (with offset keys): 404 BHP......396 ft /LBS torque
BD10's + verniers fitted: 392 BHP......358 ft/LBS torque
Needless to say the STANDARD cams were refitted
Old Oct 20, 2004 | 09:12 AM
turbinator's Avatar
turbinator
you might want to mention that for BD14 he has to valvepocket his pistons which isnt needed with BD10 ...
seems a big difference to me
Old Oct 20, 2004 | 09:15 AM
cossymad's Avatar
cossymad
ugh ugh I have BD14's/ skimmed head and non-pocketed pistons in my other cossy
Old Oct 20, 2004 | 09:18 AM
Mike Rainbird
Caraholic
Chris,
It hasn't been started yet though has it? .
Old Oct 20, 2004 | 09:19 AM
Jo's Avatar
Jo
As my car is running on greens it might be useless then fitting bd14's, and deffo not the BD10 when i read the posts above
Old Oct 20, 2004 | 09:22 AM
cossymad's Avatar
cossymad
good point, but it has been turned over and as I did this I filmed it in slow motion, then fast forwarded the tape and added sound effects. wicked.
oh and camera's never lie, even the one we stuck down the bore hole.....0.000000000001mm of clearance easy.
Old Oct 20, 2004 | 09:24 AM
Mike Rainbird
Caraholic
Jo,
DEFINITELY stick with the standard cams with 803s....
Old Oct 20, 2004 | 09:29 AM
Jo's Avatar
Jo
Ok Mike , will do that
Always looking for things to be improved , but I guess cams aren't one of those at this stage of tuning
Old Oct 20, 2004 | 10:39 AM
Turbo lag's Avatar
Turbo lag
How much can you pick up a BD14 inlet cam for ?
Dave.
Old Oct 20, 2004 | 10:44 AM
Will bd14 work with out valve cuts tho
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
