Drilling alloy wheels!!!!!!!!!!!!!!
i had a mate try and tell me that he knew a mechanic who had a set of wheels (5 stud) but were the same offset as the car he wanted to put them on.thing was,his car was 4 stud.my mate recons he had a machining company drill a 4 stud patern in the wheels so that they would fit!!!!lol sounds like a joke and took iyt with a pinch of salt. would this even be possible/safe??
I've redrilled the hubs on VW's to take 5 bolt patterns and different 4 bolt patterns.
unlikely you could drill the wheel itself safely though.
mind you I have seen old Slot mags with 4/5 bolt patterns....
you could drill a 4 hole pattern on the wheel but i wouldnt recommend doing with a leccy drill, any decent machine shop should be able to redrill the holes on the same PCD. i wouldnt like to say what strength will be left in the wheel tho
ell,when i said to him surly that would weaken the wheels,his reply was "why? look how many holes the multi fit style wheels have?and thier no weaker...." which is the only thing i thought he had a point on....... still not sure though
multi fit wheels will have been manufactured to that effect
its a bit like drilling your brake discs to aid cooling
People who know me will know what I'm on about
PassionFORD Member
the stresses on the wheel will be different to when it was machined with a multi-hole fitment. When originally machined its different to impose a multi stuf pattern then than to fully machine the wheel then go attacking it with a drill.
Like Stu says, bit like drilling your brakes after manufacturing.
Its H&R I am sure who sell PCD adaptors.
Adam Graham
06-09-2015 06:04 AM
