Wiring help!!!
Wiring help!!!
Got somr bling buttons for my series2 but aint got a clue how to wire them up
Ive got front and rear heated screens and fog light ones!!!
HELP ME
HELP ME
Team HOTHOT!
n/o - normally open
n/c - normally closed
LED Catheode - = ground for LED light
LED Cathode + = supply for LED light (or annode as its more commonly called)
Common - Common connection - usually ground.
so to use it as an on off switch - use the N/O contacts, and to light the light, use the N/O out to the LED Cathode + aswell (in parallell with whatever you are switching) - this will switch whatever you want on when pressing the button and will also light the LED when its switched on
Mark RS
12-10-2015 06:01 AM
