mk 3 cabby central lockin
Old 04-03-2008, 11:07 AM
scoobykilla
scoobykilla's Avatar
Default mk 3 cabby central lockin
ive got to fit a central locking kit to my missus'z mk3 cabby,,,
just wonderd if any 1 had dun it b4 and if it was easy enuf to do my self.. cheeRS
Old 06-03-2008, 09:39 AM
cheeky1
cheeky1's Avatar
anyone any ideas ?
Old 06-03-2008, 12:09 PM
rscabrio
rscabrio's Avatar
Smile
i used aftermarket ones on mine and just made a new loom up to fit
Old 07-03-2008, 06:56 PM
scoobykilla
Default cheeRS
thanx 4 that mate.ill give it ago...
Old 07-03-2008, 06:57 PM
scoobykilla
iz tha ur cabby in the piture
Old 07-03-2008, 08:19 PM
iansoutham
OCD Victim
iansoutham's Avatar
No need. What have you got to work with?
You need the contol box that goes to the right of the glovebox (on a small bracket), the master solenoid for the drivers door and the slave motor solenoid for the passenger door. You will need the latches as well.
Then it is a simple case of wiring the system together. Should be a +12v pickup connection in the edge of the loom behind the fusebox (red / blue trace wire that is quite thick).
Would not worry about aftermarket systems TBH as they only lock onto the original locking pin rod and if they slip, can cause all sorts of problems.
Old 08-03-2008, 12:51 AM
scoobykilla
Default 10,4
thats abig 10-4 good buddy.if i balls it up il let u kno so u can all take the piss....
nico12
31-12-2015 04:42 PM
morg65
Escort MK 5 / MK 6
23-09-2015 08:57 PM
bigryrs
07-09-2015 06:45 PM
EoinXR3
07-09-2015 05:44 AM
marky_g
08-08-2015 08:23 AM
Quick Reply: mk 3 cabby central lockin
