iscv sizes required
Old Feb 24, 2008 | 02:54 AM
NEIL A's Avatar
NEIL A
Default iscv sizes required
Hi im looking for a few sizes off of a cosworth iscv if anyone has a spare they could measure, im having no luck finding a remote housing so decided to make one while im at work and have access to a lathe, pillar drill and bar stock.
I need the diameter where the two 'o' rings are and measurements from the mounting fack to both 'o'rings and the bottom face.
This is the sort of thing i need to machine.
Old Feb 24, 2008 | 06:08 PM
NEIL A's Avatar
NEIL A
Bump for the busy time.
Old Feb 24, 2008 | 09:40 PM
NEIL A's Avatar
NEIL A
Anyone.
Old Feb 24, 2008 | 09:45 PM
rst in breaking's Avatar
rst in breaking
could this be used by any chance or does it have to be cosworth?
http://cgi.ebay.co.uk/SAAB-9000-BOSC...QQcmdZViewItem
Old Feb 24, 2008 | 09:50 PM
NEIL A's Avatar
NEIL A
Was looking on the bay earlyer and seen a few that could be made to fit, but idealy i want to use a cosworth valve as it saves cutting up the loom for different connectors.
Old Feb 24, 2008 | 09:57 PM
rst in breaking
is that not the same connector though?
Old Feb 24, 2008 | 10:09 PM
NEIL A's Avatar
NEIL A
Good point it does look the same but would need to check up on flow rates , we already have a idle map from before the new tb was fitted thats also why if possible i want to keep the cossie valve as it should just be plug and play.
Old Feb 25, 2008 | 07:00 PM
rst in breaking
fingers crossed mate
Old Feb 25, 2008 | 07:24 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I just happen to have my throttle body in bits in garage...give me 5 mins...i'll get the verniers out.
Dan
Old Feb 25, 2008 | 09:42 PM
NEIL A's Avatar
NEIL A
thanks alot..
Old Feb 25, 2008 | 10:36 PM
SillyFezzaMk1
Rubber Rhino Crew
Right....sorry mate got side tracked and finished off porting out my inlet trumpeds to a nice shine
Ok so there are 2 rubber sealing rings on the solenoid. The larger of the rings fits into a bore of bang on 30.00mm and the smaller or the rings sits in a bore of bang on 24.00mm
HTH
Dan
Old Feb 25, 2008 | 11:22 PM
NEIL A's Avatar
NEIL A
Thanks alot you dont have the distance from the mounting flange to those two 'o'rings do you so i can work out where to put the air inlet pipe fitting. My motoman out here is a turner by trade so just found his job for the rest of nightshift
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
