Interesting way of combating turbo lag...
Shamlessly stolen from xrtwo.com but thought a few on here might be interested.
http://www.brayspeed.co.uk/assets/fi...web/Favs07.wmv
Stav has no doubt heard of it before
Any idea explaing how the set up would work exactly?
DEYTUKURJERBS
Cool, seen the car loads, but never seen this vid before.
Basically a jet turbine works just like a turbo, and can easy use the massive amount of exhaust gas from the turbine to feed the turbine (or HELP) feed the turbine of the cars actual turbo.
Ie its got a turbine feeding (maybe with a Y-piece so exhaust gas from engine can help too) the turbos turbine, meaning the turbo is always at full boost (or whatever needed for the revs, easy controlled by wastegate) all the time regardless of revs or throttle position.
Not that hard
The vid makes out like the heli turbine feeds the engine itself, im pretty sure it dont, it just feeds the turbo exhaust gas to keep it spooled....
Not that hard
Ok, rather a preburner burner then? in effect it's a twin turbo, the turbo jet is feeding the car turbo...
Yeah I suppose using an afterburner was the wrong way round, but I knew what I meant.
Originally Posted by Mr Whippy
Agreed the puma looks and sounds and go's like a complete weapon....
Would like to see the thing do a proven 1.8 to 60 though
Brother works for them
Ah good.
I mean getting on for 1000bhp per tonne at a wild guess, slicks, 4x4, TC, anti lag, x-trac magic, and 60 achievable in first gear, should hope it could do that
DEYTUKURJERBS
Last time I saw it it had single turbo,may be a mistake.
Might be twin turbo tho, who knows, could be 2cyls per turbo, could be sequential, could be compund charged, just s it 4cyl dont matter.
Irritating c........
DEYTUKURJERBS
whats your idea of warrrenting it?
Originally Posted by GTechR
There was a Focus from the states, I think it was built by F2? that was a zetec running twin turbo.
http://www.superstreetonline.com/fea.../photo_03.html
steve
looks really cool.
An afterburner ignties fuel as it leaves the exhaust to increase thrust, hence the massive flames you see on the jet drag cars etc
Matt Baxter
16-09-2015 08:30 PM
turbojoe69
18-08-2015 06:41 AM
muz
16-08-2015 12:57 PM
