...engine bay now done.....
Football Cwazy
Originally Posted by lamb chops
Looks Good Phil!! I hate the way the water temp wiring runs accross the rocker on the 2wd
i rewired mine on the 3dr.....had it running hidden in the front slam panel, then under the turbo to intercooler pipe and then up to the temp sensor
it's only 1 wire and very very simple
Football Cwazy
Originally Posted by Steve the Plumber
Looks good................................but you should of left the enging bay in white!, its easier to spot oil splats etc on white engine bays than black ones
, thats why most grp4/WRC cars have white bays even when the outside colour is different. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
i think it looks good....although that weedy T3 needs to go in the bin quick smart!
The original Rouge Trader
Originally Posted by xxshepxx
you painted it black, cleaned it and put a hose on?
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Yum its still running in..will be on t34 .63
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
Billy...deceided to go as per rally cross boys and put in the bay as once set its set
...as for keeping it white to show up leaks..fook off....
..Rod its ok i run a sump guard..
Mike there is a hole in the inner wing where the other breather pipe went thru..so used that as i didnt have a longer piece of hose to route elsewhere!
Aduz.........you are correct of course..buying a Ford at my level is a wanker move
toodle pip !
Caraholic
..rich does yours hold 2.5 all the way?
No, a T34 is incapable of doing this, as the engine at high rpm (if it is speced properly
Happily retired
Rod,
You're dryer than a grape left out in the Sahara for a week
Joking aside Phil its looking good all the best with it
...Cheers Rod
..so if i set boost to 2.5bar will it automatically just drop at higher rpm and be ok?
As you see i have the rallycross boost setup so i can set to whatever with no drops..so i can easily set to 2.5bar.
Did Someone Mention TUV
...Cheers Rod
The 1st time Mark set my car up with the .63 housing (changed from a .55) we saw over 2.5 bar in 4th gear. The boost will drop off automatically as you put it because the turbo cant produce enough air for the engine. i.e the engine swallows the lot and can happily have some more, its just the turbo is too small to continue producing the air flow.. you could have your boost control wide open or have the pipe off the actuator, in effect free spooling the turbo for as much boost as the turbo can produce but it will drop off. Dont forget lean/det issues in the higher gears as well, so fuelling and igniton needs to be set-up mate.
Mike...i am goin from your posts....as boost comes in i can set to 2.5bar...all i need to know is that it will drop naturally without harm...it effectively then gives a nice spike and a nice drop higher up...ie on the t3 i can set to 20psi and it should hold it all the way ![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
..Cheers Rich...i did specify to Stu on my chip i was gonna run 2.5 bar peak..so should be ok.
