replacing bumper studs?
Old Feb 12, 2008 | 10:38 PM
percybigun's Avatar
percybigun
Twistin me melon man
Default replacing bumper studs?
i have an old mondeo back bumper where 3 of the 4 studs have come out of the foam backing. how do i fix new ones in?
i am worried in case they dont stick in properly in case the bumper decides to go bye bye's whilst the car is in motion.
Old Feb 12, 2008 | 10:42 PM
The Youth.'s Avatar
The Youth.
you need to dig out the metal support carefully then remove the broken studs, fit a bolt from the back then add a spot of weld to hold it, then put the metal support back in to the bumper foam and glue it in with tigerseal or silkaflex and let it harden before refitting..
hows that..
steve
Old Feb 12, 2008 | 10:43 PM
percybigun's Avatar
percybigun
cheers, sounds harder than i thought! can it be done without welding?
Old Feb 12, 2008 | 10:50 PM
The Youth.'s Avatar
The Youth.
you could try gluing it but if the glue breaks then the bolt will just spin!
steve
krypton
Sep 23, 2015 07:29 PM
coscor86
Sep 20, 2015 01:21 PM
NC53
Sep 13, 2015 03:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
