Checking valve clearence?
Old Feb 4, 2008 | 05:20 PM
RickDraper's Avatar
RickDraper
Default Checking valve clearence?
How should i go about checking the piston to valve clearence on a engine while doing a dry build?
Old Feb 4, 2008 | 07:59 PM
RickDraper's Avatar
RickDraper
Someone on here must be able to answer this?
Old Feb 4, 2008 | 08:10 PM
andrewg's Avatar
andrewg
play dough
Old Feb 4, 2008 | 08:26 PM
RickDraper's Avatar
RickDraper
Stick a small amount in the valve cutouts, fit head then turn over slowly by hand? Remove head then check to see how much its been compressed?
Old Feb 4, 2008 | 08:46 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yep, stick something on the top of the pistons that will squash easily, and turn it over.
Check it with the verniers at both ends and in the middle.
Do it without a head gasket, that way the values are 1.3mm more than what you measure
Aim for 2mm minimum IMHO as valves stretch in use, and so do rods!
Old Feb 4, 2008 | 09:42 PM
RickDraper's Avatar
RickDraper
Been told to do it a few times chip, with the verniers at there most extreme settings at some stage as well incase i want to change the timing?
Old Feb 4, 2008 | 09:43 PM
Chip's Avatar
Chip
Thats right mate, no good findout out that moving hte verniers causes a problem when you are on the dyno, lol
Chas
Oct 5, 2015 07:13 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
