making custom gaskets - this stuff any good?
http://cgi.ebay.co.uk/Flexoid-oil-re...QQcmdZViewItem
i need to make 4 gaskets for my roller barrels, bearing in mind its gonna see about 30psi - is this stuff any good to use?
its to join the plenum to the r/b's
also what thickness to use? says its got.5mm and .8mm
cheers
cheers
Dan, how much boost do you plan to run?
Anything near/over 2 BAR and the paper/fiberous gaskets will blow out in little pieces........might take a month or 6 months of use, but they do eventually break up.
Originally Posted by Dan@FastFord
doug, i basically want to ring its bollocks off lol
enough boost to make at least 450bhp is the plan
what other stuff is there i could use?
cheers
cheers
i had thought about o rings doug, but on the rb's there is a small hole in each that is used for an idle bypass, so it wont make a 100% seal. i could always block these with chemical metal as they wont be used anyway.
same goes for the locktite i guess
i could also just have that plate welded on to the rb's, as the car is going to pro alloy next month so im sure they could do that
ill stick a cad drawing up tomoz to show what im on about, as its on my work computer
here we go then, need to block off these, then should be able to use o-rings
If so, the trick is to use the paper/fiber gasket BUT on assemply apply a thin bead of loctite RTV on to ONE mating surface only so that the gasket is in effect glued in place, then it cant be blown outwards/sucked inwards.
track.focus'd
12-08-2015 05:53 PM
