View Poll Results: name?
Voters: 81. You may not vote on this poll
named and shamed PUMABUILD
#41
1st to 200 without NOS
Originally Posted by dojj
i think i was swayed by the "6 pots" bit to be honest
but if there is no resolution then i will be getting my money back and i'll get a hub from ebay and drop it off to you to work your magic with
along with a rim and bottom ball joint and track rod end as previously discussed
back off to the hospital so i willsee what ahppens tomorrow
#45
Never had a problemwith them myself.
Alan always bent over backwards to help me and my 65k fiesta z-s drove like a new car under their care. He's a top guy but always hassled by idiots wanting the job done to the exact minute.
Since the short blond chap ( Dave? ) left their cust service has lacked a bit but Alan is a sound guy.
#46
#48
PUMASHITE what a suprise
Have a word with Todge from the FSTOC.com and ask him if he's driven his car this year.............................................. ..........Its been with PumaShite since mid November while they fuck up x3 ECU's Id never get anything from them !!!!!
#50
Re: named and shamed PUMABUILD
and now i'm seriously getting tired of hanging around like a prick at lezzfest 2008
#51
*** Sierra RS Custard ***
#52
inbetween popping in and out of the ward (i am home for a while looking after junior) i called them
they were busy so i was asked to call back
i called back
after further "explanations" as to why it was a 330 kit and not the 360 kit my options were:
"pay me more money and i'll fit the 360 kit but i'm not sure if the bracket will be strong enough with an additional 15mm on it"
"send them back and i'll give you a refund"
option 2 me thinks
i haven't had any other work done from them so i can't say for 100% if they are good or not as some postrers are suggesting, but my experience with them will end as soon as i've got my money back
i called back
option 2 me thinks
#53
Testing the future
"but i'm not sure if the bracket will be strong enough with an additional 15mm on it"
#55
I actually Bum This Place
As a completely different question, what kind of Mondeo needs 360mm discs and 6 pot calipers for road use?
#56
#59
Sorry - just realised I'm fucking up a sale for you.
Carry on dojj
#60
Originally Posted by Chip-3Door
Its his commuter, and ive already questioned what he wanted them for, IIRC the reply was "because"
although once you are used to a set of top stoppers it's difficult to drive something without the same feeling of being able to stop in a hurry
#63
Testing the future
as martin said, big brakes are needed for big stops time after time in quick succession, but on the road in a mondeo?
anyone else got more money than sense and wants to give me some of it?
#64
there is not much difference to be honst between the originals and the 330's even with the 6 pots other than a firmer pedal
bearing in mind they are only just under 200 miles old they would have probably got more bite had they had a chance to bed in further but to have a set of stoppers that stop you in a hurry is what i'm after
the sierra with greenstuffs on 330's and wilwood 4 pots was a demon stopper even from cold and that's the feel i want to replecate on the mondeo and with a set of 18's to fill i might as well go for the biggest i can
but unfortunatly i don't have any more money to give away with month
#66
#68
just read through your post mate and at the end i thought when the pics went up i wouldve seen a fancy mondeo worthy of a big set of brakes,that things a shopping trolley!! lol you crack me up
#70
Dont let him haggle you into a figure 4 leglock
#71
In all seriousness, you should not be treated like this by anyone!
Martin sort dojj out with some proper brakes!
Also, dojj, hope your little 'un is in good health!
And ROFL at that-
"and now i'm seriously getting tired of hanging around like a prick at lezzfest 2008"
#73
ive won some bits off ford items nothing much off ebay off a ebay user called pumabuild located in brum but hasent got back to me to sort out what i have won
#74
The sad thing is he would have spent slightly more but he would now not have to measure his discs to check against his invoice and this post would never have happened..
#75
what i'm going to do is this:
get a refund from pb
get a hub from ebay
take the hub to martin
attach a bottom ball joint to the hub
attach a track rod end to the hub
leave one of my alloys (i've got a spare 18 so it's not a problem plus i've got aa cover ) with martin
then discuss budget options depending on what will actually fit inside the wheel
and then i will have what i wanted way way back about 6 months ago when i should have actually chosen the other pill
the moral of the story?
ask dojj if he's fucked something up first before figuring out he right way to go about doing it to save yourself the hassle
btw, the mrs is out now so i've been left to type replys wihtout the threat of having to anser her ever beck and call (ducks to avoid the cushion about to be throw)
i might even tell you about coronation street when she's asleep
get a hub from ebay
#77
How about a "Asl Dojj if he's fucked something up"
Glad to hear wifey is back home and all is well i presume
Dont bother posting about Corrie or Deadenders unless that slut Roxy's in a gangbang in which case i wont be going out
Regards
Ian
#78
Bling factor, plus when you get used to Upgraded Brakes on any car its kinda hard to run std brakes which is why i put cossie front and rs2k rear brakes on my lil Escort
Regards
Ian
Regards
Ian
#80
Location: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
the focus kit won't fit so they fitted a fiestat kit which only goes up to 330's
It could simply be that someone forgot to phone and tell you that, so it went ahead, but with 330's instead.
I'm sure some uprated discs and pads would've sufficed for a commuter!
Z
