tipper problem
Old Jan 27, 2008 | 12:42 PM
3001paulh's Avatar
3001paulh
Default tipper problem
hi. i just got a transit tipper and when i got it it was fine but now when i got load on the back its runs so slow i could get out and carry the bricks quicker!! anybody think it could need a new diesel pump??
Old Jan 27, 2008 | 12:43 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Try changing the diesel and air filters
Old Jan 27, 2008 | 12:45 PM
focuschivvy's Avatar
focuschivvy
mate i work at a scrapyard, and the amount of of them vans that come in with scrap and have the tipper broken is crazy!
'alright mate, could you grab this bit of steel off the back of the wagen, the tipper aint working'
if i had a quid for everytime someone said that to me, id be able to buy the fuckers a new one
Old Jan 27, 2008 | 01:25 PM
lardypants's Avatar
lardypants
if its a new gen with bosch pump, run some injector cleaner in the diesel, remove the intake pipe look inside see the butterfly flap, remove it and bin it, (two small torx) diesel filter, and turn the midrange fueling up a tad, top of pump is a round disc prise it out you will see a allen key bolt in middle locked in place with a 13mm nut, sometimes you can turn the allen key without undoing the nut, you need to turn it clockwise one full turn some ppl do it 1.5 turns i only do it one
all of the above will bring your baby back to life, if it has a banana manifold remove it and clean all the shit out inside, it will smoke less also
Old Jan 27, 2008 | 06:58 PM
3001paulh's Avatar
3001paulh
nice one mate
Old Jan 27, 2008 | 07:17 PM
lardypants's Avatar
lardypants
i do it to all the transits ive owned, as there recovery trucks i need clean running reliable trucks that go well, it really does make a big difference. other one is to check the pump timing and valve clearances
Old Jan 27, 2008 | 07:26 PM
fraser9764's Avatar
fraser9764
what year / engine does this apply too? i have just put a deposit on a 1999 flareside non turbo?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
ajamesc
Sep 8, 2015 06:51 PM
