fairly urgent phoen help required please
got myself a new phone, a nokia 5310 and it's a nice bit of kit
http://europe.nokia.com/A4515080
the problem is that i've got the usb cable stuck in the end of it and it won't come out
any ideas please?
any ideas please?
http://nds1.nokia.com/files/support/...a_ug_en-hk.pdf
page 30 is all it says about the usb connection
i followed instructions and pulled the fooker as hard as i dared and it came out without any signs of damage, but likie fuck am i going to put it back in again without someone actually telling me how to go about remioving it
thumb courtesy of junior, who just HAD to get in on the action when there is a camera about
Copied from discussions on 5310:
I purchased a 5310 phone over the weekend and got it home. First thing I wanted to do, this being a music playing phone was download some tunes. Instantly I noticed that the USB cover on the phone looked flimsy and was obstructive in getting the supplied USB cable cleanly in and out.
On just the 2nd day of owning the phone, the USB cable caught on the port cover, and as I removed it the cover popped straight out. I now can't get the cover back in and fear trying to force it will break the plastic tabs.
Do you think this would this be covered by warranty for repair or is there any easy way to get this back in that I've missed.
the plastic tab seems to be the type that, once removed, is destroyed and unable to be refitted
i suspect that it should have been the sort that you pull out and then flip down enough to get the usb to plug in but there is not enough space for it to fit and so you end up distorting the blanking plug to remove it and it doesn't seem to want to go back in again without further distortion, this in itself seems that it will just cause it to break when you try to remove it the second time
wowk
30-03-2021 07:49 PM
