HELP!! Flashing oil light on mk3 golf!- wont start
Not a ford but i'm stuck with this shit box on the road at uni
Wont start, but oil light flashes when ignition is on for a few flashes then stops, does it after cranking as well, does anyone know if its a fault code?
Any help much appreciated!!!!
cheers guys,
no it has plenty of oil, its a petrol 1800 gl, it will flash about 3 /4 times thenremain constant, doesnt start so cant see it being low oil pressure?? didnt do it when it was running?
Team HOTHOT!
Might be low oil level - most modern cars have a mowby float of some description for the oil level, if its too low, then the car won't start - this is to stop it lunching itself, or doing a "doggers"
Check the oil level and then check the wiring to the oil level sensor (if it had one fitted)
sridgett
15
03-08-2015 07:26 PM
