checking for air leaks using compressor?
Old Jan 3, 2008 | 09:40 PM
les3002's Avatar
les3002
Default checking for air leaks using compressor?
i know a few guys on here do this using a bung connected to a compressor where the air filter goes, question is do you guys remove the cams? if not how does the air not go straight out the cylinders?
just made a bung/adapter thingy in work today so wouldnt mind giving this a go.
Old Jan 3, 2008 | 09:42 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
all i know is that's what tuners do.....it works fine....bang 2bar through the system and listen
Old Jan 3, 2008 | 09:48 PM
Twellsie's Avatar
Twellsie
do they block the exhaust?
Old Jan 3, 2008 | 09:53 PM
The DIVA's Avatar
The DIVA
No......
Les......You must have a pressure regulator connected to your bung......stick the bung in,connect up the airline and adjust the pressure regulator until the gauge reads the pressure you want to test at (I use up to 3 Bar max)
Old Jan 3, 2008 | 09:54 PM
andrewg's Avatar
andrewg
no it will leak slightly but using a soapy water spray over manifold hoses etc will show any leaks
Old Jan 3, 2008 | 09:56 PM
andrewg's Avatar
andrewg
No......
i have a tyre valve on mine and it has about 4 steps for various hose sizes
Old Jan 3, 2008 | 10:05 PM
les3002's Avatar
les3002
i havnt used a regulator just an airline quick release fitting, can i not use the reg on the compressor? set that to 3 bar?
ill try it as is and see how i get on should be ok i reckon with some soapy spray as mensioned.
Old Jan 3, 2008 | 10:25 PM
The DIVA's Avatar
The DIVA
Old Jan 4, 2008 | 06:42 PM
les3002's Avatar
les3002
cheers mate
Old Jan 4, 2008 | 06:48 PM
GARETH T's Avatar
GARETH T
i made stu a nice one ages ago!
i never got around to making one for myself
Flatlinedan
Sep 18, 2015 12:41 PM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
