Translation, am i right ?
just trying to make sense of this
now i read that as analog out 1 is simulated narrowband, and analog output 2 is wideband ???
conformation from someone who hasnt been up 36 hours would be good
6. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one or
both of these wires are not being used isolate and tape the wire(s) out of the way. The default
analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is
a simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR.
AFR.
Petrucci
43
24-07-2004 04:31 AM
