Urgent! Drum Hub thread direction??
Right just a quick one, ive been trying to get the rear passenger side drum of my Escort MK5 but it will not budge!
I got the drivers side nut of as it was a normal type thread (left to loosen, right to tighten)
But is the passenger side a left to tighten and right to loosen due to the direction the car drives or is it still left to loosen??
ive tried it bothways using a snap on 18v impact drill it just wont budge but the drivers side came of easy!
any ideas?
matty
any ideas?
matty
ive had a bar on and it bent and snaped my socket
this snap on drill shud do it as it took the drivers side nut off, but the passenger side just wont nudge
doing my head in now
if i knew which way its ment to go it would be a hell of a lot easier
well it is not budging
i thought it was normal thread but i tried both ways after it didnt come of
im getting ready to scrap it
It should just be a normal thread
Wrong
Both sides are different.
The side your trying to get off will be right to loosen
well the drivers side came of as normal thread
so passenger side should be clock wise to loosen??
has anyone got a deffinate answer
its got a escos rim on it tho
the reason i need it off is because theres a locking nut on the escort rep i bought, and its different to the other 3 that were on it and what i had the key for
i started to drill down the centre of the stud and i worked my way up to 7.5mm and the drill be snapped
the drilling took 2 nites after work as the stud is so soild, only needed to get to about 10/12mm and id be able to pull the nut off
its such a ball ache
now i have to take the drum off andknock the drill bit out from the back so i can get the wheel off
i dont need the drum/beam as im changing to discs
such a ball ache its untrue
pretty certain that the hub nuts on escorts are all right handed threads. i.e turn left to undo. reason being they are usually held either by torque loading or with a split pin. get the biggest breaker bar you can find ensure the socket is correctly positioned on the nut and stand on the fucker. that should loosen it.
Cant you just hammer a socket slightly smaller over the old locking bolt/nut? works for me!
got it of and it was a opposite thread, had the biggist strongest bar on it you have ever seen, god knows why it was so tight!!
can finaly get the beam and shocks of now
07-10-2015 12:56 PM
