Electronic brake servo vac pump thingy- Where from?
Old 18-12-2007, 03:47 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Default Electronic brake servo vac pump thingy- Where from?
Ie what cossies come with as standard, but a unit to give electronic servo assistance to brakes that usually use the engines vaccum for the brake servo assistance.
Ive seen em available, but I cant remember where from.
Used on cars running ALS or properly mental cams that give fuck all vac on the overrun.
Anyone know?
Old 18-12-2007, 03:57 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
i think ive seen something like that in the compbrake cattologue
Old 18-12-2007, 04:02 PM
dojj
Resident Wrestling Legend
dojj's Avatar
they used a similar set up o the pug 405 mi16's but all you do is replace the ecu with a switch to power down after it reaches the required pressue in the system
over on fordpower, speak to madoldbugger ebcause i know we were wroking on something similar to this last summer, but i don't know if he got it figured out or not
Old 18-12-2007, 04:14 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Lloyd- Is this what you saw?
www.compbrake.co.uk/REMOTE_SERVO_UNIT.HTM
Thing thats engine vac operated by looks of it
what by sounds of that, whatever your on about has bugger all relevance to what im on about.
Old 18-12-2007, 05:47 PM
dojj
dojj's Avatar
you want the abs pump but without the abs so that you don't need to relay on the non existant servo for the pedal
the sierra pump is basicly a pump that runs up to a pressure and then switches off
tby retaining the pump side of the equation you can do away with the servo and all you need to do is wire it in
the remote servo you've shown is just that, a remote servo that has a remote brake cylinder in it and uses the engine vac to work
Old 18-12-2007, 08:00 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
oh right, i "think" i know what you mean now.
BTTT for anyone who knows a link to what im on about, ive deffo seen em!
Old 18-12-2007, 08:22 PM
Lloyd
Lloyd's Avatar
stav,thats not the bit i was looking at,i was looking in the bias valve set up.but you still need a engine vacume for them.can you use a mechanical pump,as in a ford transit type set up?
Old 18-12-2007, 08:24 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Well, Cossies have an electronic setup, dunno about other cars, Transit too is it?
But I dunno how hard it is to adapt them to work with a cars normal brake servo, or what one would be best to use.
Old 19-12-2007, 12:14 PM
foreigneRS
Testing the future
foreigneRS's Avatar
transit is not electric, it's like most diesels that have a belt driven vacuum pump so probably too much hassle for you
why not do as dojj is suggesting and use a cossie one? not difficult, just needs a bit of rewiring to make the ecu redundant
Old 19-12-2007, 12:45 PM
Graceland
Team HOTHOT!
Graceland's Avatar
BMW diesels have a vacuum pump driven directly off the camshaft if thats any use?
Old 19-12-2007, 01:41 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Nah, want electronic then can be fitted whereever.
Dont want to use a whole servo, just a vac pump to work it.
Im SURE there are aftermarket ones for rally cars running ALS and race cars running such wild cams they give next to no vac.
Old 25-12-2007, 12:36 PM
dojj
dojj's Avatar
as mentioned, maddoldbugger over on fordpower has done this and, when i spoke to him the other day, said that he would gladly share this info with you if you wanted to use it
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
The Enigma
12-09-2015 10:12 PM
focus2351
09-09-2015 09:33 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: Electronic brake servo vac pump thingy- Where from?
