Suspension???
Just wondering
If sticking Cossie RWD running gear in a mk2 Cavalier, should i start with cossie settings, or cav settings????
Just need a start point to work from really
it really depends on the pick up points for the suspension
if you are grafting in a sierra floorpan then the points should be the same as the sierra other than the shock absorber turrets
i'm not sure they'll hake a huge difference at the rear but at the front they'd need to be a bit spot on as they can affect camber and caster
go with the sierra settings and then tweak them with adjustable bits and bobs where needed
SMILER258
Sep 28, 2015 09:04 AM
