New shape mondeo, handbrake - where to adjust it??
New new shape or the pre-this-year new shape?
Easiest place to check is by the handbrake - on the focus the gaiter clips out (with a bit of persuasion - try squeezing in the long sides and levering out with a flat-blade driver), then there's a 10mm nut which tightens the cable.
Chris
Chris
nah. 17mm mate,and as above they are not all adjustable. they are prone for seized handbrake cables though,so would check those first.
bryan
bryan
Checked earlier - there is no adjuster under the centre console!!
Does the exhaust HAVE to come off or just be dropped off the rubbers? So you can get the heatshield out the way??
Originally Posted by cossie rich
you can do it on a ramp but the heat shield has to come down (you can wiggle it over the exhaust)
Ah, cool. Cheers for the help guys - it's my sisters car. After todays investigations I'll wait till my brothers garage is empty and do it in there!!
Resident Wrestling Legend
it had auto adjusters until 2002, and there was also a recall on the 2002 cars because the handbrake will sieze up because of this arrangement
get the handbarke up then pull the cable to see if there is any slack in it
it might even be the caliper thats at fault
wowk
30-03-2021 07:49 PM
