Another GT 30 question
i thought most ppl had the external gate on the other side?
as your mixing hot and cold together like that, not
to mention the pipe restriction you now have!
the compressor cover fyi does indeed turn to any angle
Will just have to see if the pipe fits ok i guess' If not then yes i will have to spin the comp housing round
Not welcome...
that looks well close! what have PJ said about it? i would Contact Martin @ reyland mate and see what he thinks as it looks like the Exhaust manifold is going to melt your boost pipe
Almost there!
Have you got an alternator drop bracket on there atall yet?
thats exactly how it was on a mates 3door
oh and Doug, you need a hose clip on your water pipe where it comes off the thermo housing
Yes buddy
O and Kelv regarding the hose clip
escort mk4 cossy 4x4
Originally Posted by Porkie
Why didn't you use the Reyland jobbie. Surely its far better positioned even to my untrained eyes!
Originally Posted by black scoob
could you not get some of the pipework ceramic coated??
Scott
Scott
Probably going to take the engine back out next year for some paint on the shell anyhow
i'd say if your intent on keeping the ext gate there,
you'll ultimately have to have a hard pipe boost
pipe off that turbo outlet and even then you will
still need heat insulation pad/wrapping etc
in between.
in between.
Scott
Scott
