Just bought a 1080p TV Quick Question
Just bought a Samsung 40inch 1080p HDTV, and got a samsung dvd player with it, now will i notice much difference using a scart than a HDMi cable in quality wise? Im not upto date on these things
and is it worth buying a £60 hdmi lead or will a £10 one be the same? only need 1 meter
Thanks![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Edited to suit mk5
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Thanks
Edited to suit mk5
Originally Posted by MATCOS
I bought some for about 35 quid and I would say it made a difference pic wise, HDMI doesn't transmit sound though so you will still need good audio cables.
Originally Posted by scruffythefirst
HDMI is a digital signal so it doesn't matter if the cable cost £100 or is a wet bit of string. Plenty of cables around for £5-10
BTW.... no DVD player will have 1080p output native unless it is HD-DVD or Blu-Ray software. Anything else will just be upscaled to the displays native res and a 1080p display will do that in any case, so unless the other device upscaler is of better quality the point is pretty worthless.
Thanks Fagin,
Its got a HDmi sticker on the front so does that mean its a HD-DVD player or ?
New to this stuff
So is it worth me getting a HDmi cable
New to this stuff
HDMI is just the interface standard between two devices.... like a scart socket is, except HDMI is part of the HD-Ready agreed standards.
HDMI means that you can output a digital signal in to a device that accepts a HDMI or DVI digital input.
Unless you player is HD-DVD or Blu_Ray (it will have an appropriate label on the player and these cost a lot more than normal DVD players) it will be a standard DVD player. Having a HDMI output even on a normal DVD player will ensure the picture should be crisper with better colours than an analogue component or RGB Scart output. It may also mean the player has an upscaler (to take the DVD resolution to whatever the upscaler will scale to), but as I have already said, you display will already do this function natively, so unless the upscaler in the player is better (generally a better upscaler on a player will mean the player will be quite expensive) you may not benefit from the player doing the upscaling.
Confused??![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Basically.... if your devices support HDMI use it. Plug the thing in and enjoy your new toy without worrying about the technical stuff too much!
Confused??
The 60ft Launch King
Usually an upscaler will do 720p or 1080i.. As Shawn says HD-DVD or Blue-ray will do 1080p nothing else... Even sky HD is only 720p
Picture will be better with a High Definition Multimedia Inferface (HDMI) than a scart lead. i got a 1 meter one (all i needed) from cyurryd for a tenner!
Bargain!
Bargain!
One glaring ommision I see here...
The whole point of a 1080 set (beit p or i) is to be able to view 1080 "one-thousand-and-eighty" horizontal lines on the screen, thus more detail.
A scart only transmits 576 lines. HDMI, being a digital cable, will be able to transmit 1080 lines from a correctly encoded HD-DVD, Blu-Ray film, or compatible games console, PC etc.
HDMI does carry uncompressed video as well as up to 8 channels of uncompressed LPCM audio.
However if you use a HDMI lead with a DVI converter at one end (ie your PC outputs DVI and your TV takes HDMI, or vice versa) then Sound won't be carried, as whilst DVI has the ability to carry over the video content, it cannot handle sound.
As said, unless you are using a HD-DVD player or Blu-Ray player, it is doublt full you will get 1080p. I take it your DVD player is a standard SD-DVD player, with a HDMI connection that can "upscale" right? Same as mine then, and in this case, you probably get 1080p. Maybe 720p, but this is upscaled, so still won't be as clear or detailed as HD-DVD or Sky-HD at 720p.
My advice? Use an HDMI lead for your upscaling DVD player. The player will upscale it to 720p, but the TV will then re-upscale it to 1080p. If you use scart, the inital output is 576i, when then has to be re-upscaled by the TV to 1080p, so better off with the HDMI cable @ 720p.
And don't spend more than £25 on a HDMI cable. Whilst the quality of the cable DOES actually make a difference to performance, the degree of this isn't a lot. It's mainly down to connectors and quality of the inner cable itself. Cheapo pound shop ones hav shit connectors and shit "joins" joining the connectors to the inner cable. *Most* more expensive ones (from trusted suppliers) will have better connectors and better joins, and probably an inner core capable of handling higher ohms, thus transmitting the pulses better.
This Hi Def stuff has got to be about the most complicated thing ever...
Guest
Posts: n/a
was in currys today looking at some big flatties they so try and confuse you into buyin shit i let him run his pitch then asked is it 1080p he said yeah 1080p upscale im like so it isnt and your lieing?
the 50" badboys at the mo i was looking at i think thiers only panasonic and samsung that do true 1080p so watch out im waiting for a sony tbh
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
As said, might not have used the correct terminology, but was just trying to get the point across in an easy way to understand it
Yea, just a terminology thing.
Here goes...
The cables impedance is 75ohm, which will affect it's ability to carry current.
It's called impedance not just straight resistance as it also has a capacitance, and the resistance will be different depending on the frequency of the signal you are trying to pass.
Hope that makes sense, it's been a long weekend.
The noticeable difference between the cheap cables is more likely to be due to poor terminations on the connectors, as you said...
Here goes...
Got mine of ebuyer for £3
Here goes...
Here goes...
Kinda
the 50" badboys at the mo i was looking at i think thiers only panasonic and samsung that do true 1080p so watch out im waiting for a sony tbh ![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
I've got a 50" Samsung 1080p and it's wicked!
Guest
Posts: n/a
There's a 50" Samsung plasma in a cash converters near me for £850.. No idea if it's 1080p, but then I don't really care
It calls my name when I drive past it tho ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
you can get brand new ones for around that money!
Here goes...
Here goes...
Kinda
i want to ask both of you the same question ..
i bought gold ended scart leads as was having problems with the tv
http://www.richersounds.com/showprod...CAMB-SCART-SC5
and a freind said i had wasted my money if the screen did not have the same 24K gold plated connectors ie digi box sky whatever
The Cambridge Premium Scart offers a significant upgrade over standard SCART leads, and offers impressive engineering for the money. Double shielding reduces interference whilst an Oxygen Free Copper conductor improves clarity of both sound and picture.
The metalised plugs reduce noise levels still further, whilst the 24K gold plated connectors give the lowest resistance connection possible. The Cambridge Premium Scart offers true 75ohm geometry for optimum video performance and detailed sound quality. Release the best from your system today!
was i mugged
0-60 in 17 seconds (eek)
The main difference here is that digital data off the dvd is sent to the TV as digital data via HDMI, whereas SCART requires the DVD player to convert this digital data to analog, send it to the TV which will convert it back to digital, one of three reasons why SCART is technically worse.
Then, Scart can be used to carry Composite, S-Video and/or RGB (from worse to best (for scart)).
Composite over scart will look a million miles worse than HDMI, s-Video not quite as bad, RGB nearly as good
Remember, DVD is 576 lines, regardless of how you carry the signal to the TV, it's 576 lines of information that are stored on the DVD.
HDMI doesn't upscale, it's only a piece of cable and digital communication standard between devices (in fact four standards now, 1.1, 1.2, 1.3 and 1.3a).
The DVD player may upscale 657 to 720i, 720p, 1080i (unlikely to support 1080p), all of which can be carried over HDMI (or component).
A plasma or LCD TV is also capable of upscaling analog TV (525 lines), DVD 576, up to 720 or 1080 depending on the model, etc...
All that really matters is which is best (dvd player or telly) at upscaling from whatever to 720 or 1080. Only your eyes / reviews can tell you vy trying different combinations.
Note: If you output upconverted 576 to 720 out of your DVD, your TV will then have to upconvert again to 1080, might be best leave the upconversion off in the DVD and leave the TV to do it all.
Think of it in terms of re-heating meals... a meal cooked once (756-1080) usually tastes better than one that have been prepared by one chef (DVD 576 to 720), then re-heated by another (720 to 1080).
As for the HDMI cable, unless you have a top of the range plasma screen and a top of the range DVD player, you are VERY VERY VERY unlikely to notice a difference between £5, £10, £25 or £250
Hope this helps
was i mugged
PLEASE BE GENTLE ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
was i mugged
However, as I said in my previous post, if you paid £19 for your DVD player, there is no point (at all) spending £50 on a scart cable
avid-fan - Essemtially what your friend says is true. Gold plated connectors when coupled with gold plated connectors (ie, a lead with glod plated ends and a TV/amp with glod plated inputs) will give a superb connection, but couple a gold plated scart (for example) with a non gold plated scart input, then it won't perform the same. In extreme cases, it can actually cause a LOSS of quality in the connection, as the gold against nickle (which scart and RCA connectors often are) can suffer from oxidation between the two.
Read this for more info - http://www.avforums.com/forums/archi.../t-163888.html
frog - I was trying to phrase things in an easy to understand sense, whilst trying to retain a bit of technical info
I understand that HDMI is a fully digital "data" cable as opposed to scart which is AV. But I was actually referring to HD-DVD and.or Blu-Ray
Which will output at 1080i/p. All UK terrestrial, satellite and cable TV sources are in 576i format (unless they are of the HD variety, ala SkyHD and VirginHD, which are mostly in 720p, some in 1080i), as are all PAL SD DVD's. US (NTSC) DVD's are in 480p format. HD-DVD's and Blu-Ray are in either 720p, 1080i and 1080p, which is where my comment was coming from - the HDMI here will transmit those 1080 lines to a TV that can recieve them.
An "upscaling" DVD player connected by HDMI will still output 576 lines (that SD-DVD's contain) but will upscale the image to 1080 lines before it hits the TV. The idea behind this is that if the upscaler in the DVD player is better than the one in the TV, the picture quality will be better because the TV doesn't have to do any processing/scaling. However, unless you are spending decent money on an upscaling DVD player, this isn't likely to be the case. People seem to be under the impression that just cos it has a HDMI connection it must be HD quailty - well that ain't gonna happen from a £40/£50 DVD player
Same as CD players - there are reasons people spend £200 on a DAC, and it's cos the DAC in a £50 CD player is shite
Guest
Posts: n/a
the only reason a decent cable can out perform another is through shielding the signal from RFI.
Think about how poor the quality of internal wiring and shitty PCB's are inside either the TV or DVDP, do you think a £100 cable will make those any better?
As thrush said, as long as the cable is of decent quality with proper shielding, decent joins and good connectors theres no reason to spend silly money, gold plated or not, gold is probably the poorest conducting metal out there, silver is the best (not stirling or jewellrey silver, proper %99.99 pure stuff) closely followed by copper, all gold plating will do is stop the bare copper from oxidising and creating a poor connection, which lets be honest isnt going to happen in your average home, maybe outside, even so, the time it takes to oxidise it would be ready for replacing anyway
