The end?? Turbo failure pics.
Old 25-11-2007, 04:26 PM
  #41
leecavturbo
leecavturbo's Avatar
Originally Posted by Stavros
Dont think its ever been proved either way that DVs help fuck all in this respect.
Some big tuners (Roger Clark Motorsport for example) dont even run em as they just give another possible leak and no noticable help anywhere.
Rarely if ever see top turbo race cars running DVs, even LeMans etc where surely theyd fit one as they got some long ass racing to break the turbos with...
iirc garrett say it is required for GT Series Turbo's running high boost.
other turbo's possibly run forever without one like you say
Old 25-11-2007, 04:29 PM
  #42
leecavturbo
Originally Posted by Kev.H
does that mean i can ditch my re cric on my diddy gt25 or whatever the FRS has there was a white frs @ the PF track day he didnt run one
i know what i'm sticking with. hate the sound but
you just know relieving unwanted pressure has
to be a good thing ?
Old 25-11-2007, 04:32 PM
  #43
scoooby slayer
scoooby slayer's Avatar
i totally agree i wouldnt run 2 bar + without one
Old 25-11-2007, 04:33 PM
  #44
Stavros
DEYTUKURJERBS
Stavros's Avatar
ALL turbo companies will say you need one, it covers their arses a bit more as in theory it WILL take some of the strain off, though the reality is there isnt much strain anyhow.
One thing we dont know, will need Christian to tell us, if did this happen as he let off the throttle?
If not its got fuck all to do with DV or not as it
Old 25-11-2007, 04:34 PM
  #45
Kev.H
Kev.H's Avatar
yeah but on a diddy focus you aint ever running 2 bar without going pop 21psi wonder what that track focus runs he had standard manifold etc maybe just remap, decat etc
Old 25-11-2007, 04:36 PM
  #46
dumped
dumped's Avatar
Surely its only to get rid of shock loads from the compresser stalling. I thought they first came about to stop the pigeon mating noise lol then folk started to vent them to atmosphere as a "look at me"
Old 25-11-2007, 04:38 PM
  #47
s2 ben
s2 ben's Avatar
am i missingsomething when did christian lose the top speed record and by who
Old 25-11-2007, 04:39 PM
  #48
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
IMO GT series turbo's DO require a dump valve, Porkies car has 2. We did exactly the same damage as C&B on the dyno when we ran my old Millington engine without a DV.
Old 25-11-2007, 04:40 PM
  #49
Kev.H
Kev.H's Avatar
I prefer a pigeon turkey chuckle rather than chuffing my recric still makes a stupid chuffing noise when I have the kone air filter fitted
Old 25-11-2007, 04:44 PM
  #50
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Check his sig thats all i can say the mag will reveal all, i rather slipped up
Old 25-11-2007, 04:47 PM
  #51
Kev.H
Kev.H's Avatar
Is it better to run a DV or a Re Circ Valve
Old 25-11-2007, 04:49 PM
  #52
dumped
dumped's Avatar
If this seems to be the case I would say that GT series turbos sound weaker. I have seen a lot of "undumped" boost run though conventional T series turbos with no dump valves with no issues over a good lot of testing. A good range of sizes too including some larger ones.
Have these turbos "honestly" not been subjected to surge as well as not being "dumped" As this would make a more sense for them to be getting a lot of abuse? Would guess its a factor.
Old 25-11-2007, 04:59 PM
  #53
leecavturbo
its the relieving of the pressure that counts so either
i'd guess.
Old 25-11-2007, 05:43 PM
  #54
RWD_cossie_wil
RWD_cossie_wil's Avatar
I have to agree with Martin here, what happens to all the air when a throttle is snapped shut from 7500 RPM? That is a LOT of air, the turbo which is possibly doing close to 100,000 RPM will get a big shock loading with the air suddenly "stopping" infront of it, which will cause the compressor to choke and again the pigeon noises you hear is actually surge, air being forced backwards through the blades which can quite happily destroy a turbo.
It is a very under estimated effect, I work on aircraft, and have seen the damage to engines when they surge, it is scary how much damaged compressed air can do ... The jet engine is basically a turbo with a combustion chamber in the middle, I will post some pics up of a surged engine when I am back at work, you can see all the compressor blades bent the wrong way ....
So I would ALWAYS run a dump valve on anthing bigger than a T34, remember a T4 has the same size shaft as a T3, and the GT series have bigger wheels front and back, so the leverage against the shaft will be much greater than a T3 etc..... If you don't like the DV noise, use a recirc valve.......
Hope you sort it christian, don't let the fuckers fob you off ,I had a BRAND NEW T34, that threw its guts after 300 miles , just after the car had had an oil and filter change, and got the old "oil contamination" excuse , but after a bit of an argument they honured the warranty
Old 25-11-2007, 05:56 PM
  #55
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
To clear this one up, I don't currently run a Dump Valve, but I don't run 2-bar of boost either, the failure occurred at 1.8 bar. That said, I am going to run one if it goes back together.
However, the turbo failed at 160mph, which is well into 5th. I'd have shifted into 5th at just after 130mph, so don't think the DV would have helped this.
My decision to run one is more because I am happy with how Gary's is with his DV (noise etc) and for the sake of the cost of it, I will err on the safe side.
If it makes the car run like shit, it will come off again.
Old 25-11-2007, 05:59 PM
  #56
Rob M666SCC
Rob M666SCC's Avatar
Have you considered the EGT's ???
Old 25-11-2007, 06:04 PM
  #57
Stu.H
Stu.H's Avatar
Daz runs 2 DV's on his dolomite as well
Old 25-11-2007, 06:05 PM
  #58
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
That is exactly what happened to AndyG's GT turbo (doing the same kind of thing), except his happened with throttle lift off . This is why I personally don't like the small GT turbos as in the aid of quick spool up, the shafts are made relatively spindly compared to the T series ones.
If I had one of these turbos, it would DEFINITELY be fitted with a dump valve, as although Christian's didn't fail in a lift-off scenario, it could have been an accumalitive amount of damage from previous lift-offs that twisted the shaft until it finally had a catastrophic failure.
  #59
Porkie
Porkie's Avatar
Gutted for you mate
Fooking cars
My Skyline lunched its Turbos at Brands Hatch I wasn't even driving it!
Modded cars man... proper pains in the ass!
Old 25-11-2007, 06:07 PM
  #60
Kev.H
Kev.H's Avatar
please someone is a recirv valve as good as a dump valve
Old 25-11-2007, 06:11 PM
  #61
Mike Rainbird
Caraholic
Its the same you gimp, it just doesn't vent to atmosphere .
  #62
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Yes.
Old 25-11-2007, 06:14 PM
  #63
dojj
Resident Wrestling Legend
dojj's Avatar
i've been in this position plenty of times before
what you will do in a few months after you've got rid of the car will be to justify the whole cost issue of stopping all this "fast car nonsence" but in the back of your mind there will always be that lingering doubt that you could have sorted the problem fairly easily
always the easiest thing is to give up, and sure, you can give up, but park the car up somewhare out of sight and in a few months come back and say "right youlittle git, let's find out what went wrong" and then you'll feel much better
and the sun'll be out too
Old 25-11-2007, 06:15 PM
  #64
M K
M K's Avatar
my gt30 doesnt run a dv......and i run anti lag with it too was told it will be fine as the als will not see more than 900deg i think tommy said,
i have surge issues tho
Old 25-11-2007, 06:18 PM
  #65
Twellsie
Twellsie's Avatar
[quote="Kev.H"]please someone is a recirv valve as good as a dump valve [/quote
effectively the same thing, dump valve vents to atmosphere, recirc vents the air back into the induction system but both do the same job
Old 25-11-2007, 06:44 PM
  #66
Kev.H
Kev.H's Avatar
good job for you then cos I would of wanted a refund on my re circ for a dv which I beleive you sold me
3i Jim
20-11-2015 05:12 AM
Matt Baxter
16-09-2015 08:30 PM
mrknifey
30-08-2015 11:48 AM
IAN RS2k
18-08-2015 07:51 PM
Quick Reply: The end?? Turbo failure pics.
