Now where to modify rear beams ?
Old 27-11-2007, 03:51 PM
  #41
JamesH
JamesH's Avatar
Originally Posted by DaBoy12s
You have already been told by Ryan . The Grp A rear beams are only 9°, whereas the Ahmed / Adrenaline ones are better, due to not being constrained by rules, so have been built to the 6° optimum. The Ahmed one is £1k exhange and can be bought through me . Please be aware that the Ahmed one is fully adjustable for camber AND toe, whereas I believe the base Adrenaline version ONLY does camber. Therefore make sure that you are always buying like for like when comparing prices .
Not sure if you are right there Mike, Adrenaline do 3 different stages
http://www.adrenaline-race.com/forum...opic.php?t=530
Well considering Charlie has the base version of the Adrenaline beam fitted, and they only adjust the camber, I think I am right . You do know what I mean by the base version don't you? As in the cheapest version that he does - the "base model" .
As above Mike is right (as usual ) , the Stg1 ADR 6° rear beam is only adjustable for camber, and not toe, to do camber AND toe you would require the stg2, Charlie (my father) chose the stg1 because he was advised that he did not require toe adjustment for fast road use, which is also suggested in ADR's layout of their prices for their 6° rear beams (he never and will not track the car); and he is also not as flush as some on here
However he did have the car setup yesterday, toe on front and camber on rear as per Mike's settings (Thanks for answering the phone yesterday Mike ). Charlie is VERY pleased with it, and with a quote of £180 + VAT to exchange his stg1 arms for stg2's (including the extra rose joints) it is something that he is not looking at doing in the near future. Namely because he is very happy with the car as it is, and is uncertain just how much benefit toe adjustment on the rear would make to a road car that is not very often really driven to the limit of the cars handling capabilities/tyres. And also that making the front completely adjustable (to match) and reliable by not putting stress on other components is extremely expensive.
Personally if you feel camber AND toe adjustment on the rear is necessary ADR's stg2 because it is all done with rosejoints whereas Ahmed's is slotted in the beam I believe, I am not sure how this compares, I trust Mike will know the answer though.
James
Old 27-11-2007, 03:56 PM
  #42
Twellsie
Twellsie's Avatar
but why are we considering the base one? when stg 2 is £850 +VAT
Are you (and that lanky streak of piss ) REALLY that stupid?
The point I was making is that don't go comparing the Stage 1 version of the Adrenaline beam with the £1k Ahmed one, and thinking that there was a huge price disparity with the two, when Ahmed's one should only be compared with the Stage 2 Adrenaline version, as Ahmed does only one version and that is fully adjustable .
but Mike it was you that was comparing the Ahmed beam to the Adrenaline stg1 beam by saying that the Adrenaline beam is not fully adjustable
Old 27-11-2007, 04:01 PM
  #43
Mad Matt
Rally nut
Mad Matt's Avatar
Prices for adrenaline setups :
Originally Posted by Adrenaline-Race.com
Stage 1 (road/trackday) outer bushed/inner insitu adjustable rosejoints for camber adjustment RRP£600+vat
Stage 2 (serious trackday/race) inner/outer insitu adjustable rose joints, camber and tracking adjustment
RRP£850+vat
Stage 3 as above but tubular arms
RRP£1650+vat
All prices are subject to a standard beam in exchange or £100+vat core charge.
Does than mean if I add 100£ I will get a NEW rear beam AND arms or ?
Btw Tim could you just post more feedback about the back end of the cars rather than just 2 words ?
Old 27-11-2007, 04:02 PM
  #44
jb fletch
MAD Carbon Cossie
jb fletch's Avatar
Back to Mike
Old 27-11-2007, 04:04 PM
  #45
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
And I thought that I had adequately explained the reasoning behind that as well, but obviously not . I was pointing out that the £1k Ahmed one is fully adjustable, so should only be compared like for like with the Stage 2 version of the Adrenaline beam, to prevent anyone from making a mistake believing that the the Stage 1 version of the Adrenaline beam would (at far less cost) do the same thing as the AB beam, only to find that it didn't adjust the toe . I really hope this clarifies to yourself and the thin one, before I lose the will to live .
Old 27-11-2007, 04:07 PM
  #46
JamesH
JamesH's Avatar
And I thought that I had adequately explained the reasoning behind that as well, but obviously not . I was pointing out that the £1k Ahmed one is fully adjustable, so should only be compared like for like with the Stage 2 version of the Adrenaline beam, to prevent anyone from making a mistake believing that the the Stage 1 version of the Adrenaline beam would (as far less cost) do the same thing as the AB beam, only to find that it didn't adjust the toe .
I wonder who shitout and thought that originally
Mike is just trying to let others learn where tohers have possibly mis-understood too
Old 27-11-2007, 04:08 PM
  #47
Mike Rainbird
Caraholic
James,
I didn't want to name names, but your Dad sprang to mind when I was posting this .
Old 27-11-2007, 04:09 PM
  #48
Mad Matt
Rally nut
Mad Matt's Avatar
All is clear Mike, no problem, well the group A setup doesn't looks that much interesting regarding the price compared to the stage 2 adrenaline setup or ahmed's rear beam, but other than the material used (mag arms, ...) it must be stronger, and better isn't it ? Has anyone even tried that setup on a car to compare with standard modified ones, or is that just theory to say the 6° is better than the 9° ?
Trying to push the discussion further.
Old 27-11-2007, 04:10 PM
  #49
Mike Rainbird
Caraholic
RRP£850+vat
RRP£1650+vat
They would not be brand new, but reconditioned second hand items .
Old 27-11-2007, 04:14 PM
  #50
Mike Rainbird
Caraholic
If you want a Grp A 9° one, Escosracer has one for sale that is sitting in my garage .
Old 27-11-2007, 04:16 PM
  #51
ian sibbert
ian sibbert's Avatar
Originally Posted by buzznwood
Originally Posted by maxrs16
does anybody no what hub carriers you would use withe the diff cradle setup
The WRC cars just used the gravel spec front hubs, which look pretty much just like the sierra group a front hubs, they of course had a different steering arm bolted onto the bottom 9097070 (RH) & 9097071 (LH)
Without going down the 909 part route the only options that spring to mind would be to do the same as the rs2000 4x4 / mondeo 4x4 these have the same lower 3 link setup, the only difference being the angle of the tie rods. The hubs used on the rs2000 where just the front hubs of a mk3 fiesta, not sure on the mondeo but it shouldn't be to hard to find out the fins number for the part and see if it unique to the mondeo 4x4 or shared with another car.
It would be ludicrious to go down the WRC esc route....it'd cost you about 3K before you even buy a diff....all would have to be on either 9" or 7.5" drive shafts, stub shafts and drive flanges. The rear wrc hubs are unique to the WRC esc, they are as you say gravel fronts, but from the WRC esc....they are 15mm shorter and use a different bearing than that used on a grp'a' saph or esc, the use of these hubs has a bearing on the geometry...the esc wrc does have near perfect geometry but it takes a lot of fiddling to dial it out......un-equal lateral links dont make perfect geometry
IMO fully adjustable rear beams are a complete waste of time and money on anything other than a competetion car......escorts are renowned for being twichy under geometry change....simple answer is, just get a sierra... the longer wheelbase makes a far better package.......
Old 27-11-2007, 04:17 PM
  #52
lead_foot
is awesome
lead_foot's Avatar
Buy an S14 full adjustable kit front and back for £400.
Old 27-11-2007, 04:18 PM
  #53
JamesH
JamesH's Avatar
Hopefully everything is clear now Mike
I would just say, if you cannot afford to spend £1000 on a rear beam (like Charlie couldn't) but can spend £700 and just get adjustable camber as you can always trade in your stg1 arms for stg2 at a later date As I believe the main issue is the camber anyway, and not the toe?
Old 27-11-2007, 04:20 PM
  #54
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
and if your a decent driver,you can just drive around any shit handleing charactaristics the escort has anyway.
and if your not a decent driver,then subaru and mitsubishi can help you.
Old 27-11-2007, 04:25 PM
  #55
Twellsie
Twellsie's Avatar
ok Mike, i am glad you have got your head round it now
Old 27-11-2007, 04:30 PM
  #56
Mike Rainbird
Caraholic
Okay stupid .
Old 27-11-2007, 04:44 PM
  #57
col cos1
col cos1's Avatar
good thread will be after 1 of these next year
Old 27-11-2007, 05:25 PM
  #58
Mad Matt
Rally nut
Mad Matt's Avatar
I have the possibility to buy a full rear beam group A setup with mag links (was used on a gravel car) but my question was to know if the group A setup was really better than a standard-modified rear beam setup, because there is a price difference, the parts are harder to find and of course more expensive, so without a quite noticable difference, I don't know why I should go for the group A setup.
Old 27-11-2007, 05:27 PM
  #59
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
RRP£850+vat
RRP£1650+vat
Are the Ahmed items new then
Old 27-11-2007, 05:28 PM
  #60
Micky The Finn
Former Sponsor
in 3 years time the group A square axle will be worth 50% more than it is now,whereas the welded up standard item will be worth very little,or will have snapped under use (not that that happens though eh!!).
Old 27-11-2007, 05:33 PM
  #61
Mad Matt
Rally nut
Mad Matt's Avatar
RRP£850+vat
RRP£1650+vat
Yes quite a big problem because you never know how have been used the parts so I would be only interested in new parts (beam and arms). I know the rear beam can be found on ebay, but unsure for the arms.
Don't know if I should start going the group A route yet.
Btw Mike which type or rear beam Michael has for sale (tarmac, wide tarmac, gravel) and how much ?
Old 27-11-2007, 05:42 PM
  #62
Mike Rainbird
Caraholic
Charlie,
Either your existing beam is modified as per the pictures that YUM posted up and then powder coated, or it is done on an exchange basis using a second hand beam.
Personally I have never heard of one of the AB beams breaking and my one landed from a 7ft high jump and only bent one of the arms like a banana (but it didn't break), so I don't know to what type Tim is referring.
Xen,
You will have to ask Michael, but it is green like the one Tim posted a picture of (if they are colour coded)?
Old 27-11-2007, 05:54 PM
  #63
Charlie Chalk
Unknown.
Charlie,
Yeah thats what I though.. I remember Dave telling me his was away to be modified, Just got muddled up with the way you worded it, as if Adrenalines arn't new, but Ahmeds are.
Old 27-11-2007, 05:57 PM
  #64
Micky The Finn
Former Sponsor
green is gravel black is tarmac and widetrack,blue is sapphire.
Old 27-11-2007, 06:03 PM
  #65
Mad Matt
Rally nut
Mad Matt's Avatar
Which can sometimes be wrong. Some are listening green beams as wide tarmac, and there are also some red ones.
Old 27-11-2007, 06:08 PM
  #66
ian sibbert
Matt,
Is your car a competition or road car?
If its a road car, be careful putting mag arms on....they will deteriorate very quickly on the road and these definately do snap, ive seen even good ones snap.....
Ian
Old 27-11-2007, 06:09 PM
  #67
Micky The Finn
Former Sponsor
green rear arms are gravel,period.not up for discussion.
red,somebody has had the painters in then.
Old 27-11-2007, 06:14 PM
  #68
Mad Matt
Rally nut
Mad Matt's Avatar
Originally Posted by ian sibbert
Matt,
Ian
Ian the car will mostly be used on hillclimb races/stages, sometimes on racetrack, sometimes just to have fun in the moutains so won't be used a lot.
So I guess that if I clean up the underside of the car carefully and if I dry carefully every bit of water on mag parts and then put these under a high-flow air-pressure jet they shouldn't rust and then crack ?
But with your experience, how greater do you recon the group A rear setup can be compared to the modified standard rear beams ?
Sorry for my english...
Old 27-11-2007, 06:18 PM
  #69
Spiky
Spiky's Avatar
my mate has a malcom wilson esc cossie
on there rear it has a grp a beam and it's blue with mag arms
what is that?? tarmac? gravel?
are they worth much?
  #70
Micky The Finn
Former Sponsor
Matt,
Ian
nope,what you do is before fitting them you clean them dry them then repaint covering all exposed parts very well,should last for years and years if looked after.
Old 27-11-2007, 06:19 PM
  #71
Micky The Finn
Former Sponsor
try being a little more vague!!!!
Old 27-11-2007, 06:21 PM
  #72
Mad Matt
Rally nut
Mad Matt's Avatar
Matt,
Ian
Ok thanks for the advice. Should I remove the existing paint before repainting over or not ?
Old 27-11-2007, 06:25 PM
  #73
Micky The Finn
Former Sponsor
i never have,done over 50 events in a group A escort and never had any mag arms break,in 10 years rallying ive only seen one brake,and that car was a dog.
Old 27-11-2007, 06:28 PM
  #74
Spiky
Spiky's Avatar
this is what it looks like
Old 27-11-2007, 06:29 PM
  #75
Micky The Finn
Former Sponsor
thats a very old sapphire rear axle.
Old 27-11-2007, 06:30 PM
  #76
Mad Matt
Rally nut
Mad Matt's Avatar
Tim so you just repaint the arms and links and its' all ? Sounds easy.
Spiky, looks like a saph group A setup.
Old 27-11-2007, 06:32 PM
  #77
Spiky
Spiky's Avatar
ok cheers guys
can i ask how you tell??? lol i have no idea, nor does my mate
Old 27-11-2007, 06:39 PM
  #78
Micky The Finn
Former Sponsor
they deteriate with age,magnesium is eaten by oxegen in the air,they do require looking after but in my opinion are worth it.
Old 27-11-2007, 06:41 PM
  #79
Spiky
Spiky's Avatar
is that beam any good? worth much?
Old 27-11-2007, 06:46 PM
  #80
Charlie Chalk
Unknown.
Matt,
Ian
Id get the arms bead blasted, but use a plastic media.. One thing though, Mag is a cunt to have painted as it as air bubbles in the surface
Quick Reply: Now where to modify rear beams ?
