fuel piping ? anyone
if youve seen my resto thread you will see im fitting a yb to a rst, one quick question, the original metal fuel pipe that sits under the steering rack the feed one i need to connect to that and then to the cossie fuel rail what should i use as i thought maybe just fuel pipe and clips but wont that just pop off due to the pressure ? dont fancy aero quip though
escort mk4 cossy 4x4
the fuel pressure on a cossy is 3.5 bar at idle,just over 50 psi,up to you but i wouldnt like to risk petrol spraying over a hot engine.aeroquip is expensive,but its also very safe.
Originally Posted by lloyd
the fuel pressure on a cossy is 3.5 bar at idle,just over 50 psi,up to you but i wouldnt like to risk petrol spraying over a hot engine.aeroquip is expensive,but its also very safe. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Lukesville
If you contact think automotive as i mentioned above you can buy push fit hose fittings.
so you can mate up existing fittings with aeroquip fittings and push fit the same diameter rubber hose on.. No need for jubilee clips either. works a treat.
cost wise to do your engine bay fuel lines.
£50 tops.
£50 tops.
155lee
06-09-2016 11:10 AM
