trouble starting rst from cold
it takes about ten seconds to start from cold and runs lumpy for a few mins
give it a minute oh two it will start straight away and run fine
ive changed the cold start valve under the inlet but it is still doing it any ideas cheeRS
was set up about a month ago did it before that anyway but it was summer then and never took this long!
i have had it unpluged but im leaving for work just after 5 everymorning and it always trys to cut out when its cold
does it come on choke at all in the morning
and do you let the fuel pump prime before you start it
try putting some injecter cleaner down it too
also how you been lol
yeh let it prime ive done allsorts even had airbox off and opened the flap a little on metering unit, cant understand why its fine when its warm
got a 1.9 for it now aswell gup, cossie discs to go on allround bigger cooler, lots of crome stripping a full s2
well ive got another head stage 3
so il just run it till i but some new shells in the 1.9 as the oil pump has gone and spun a shell!!
got allsorts now buddy mahle pistons, stage 3 turbo needs a rebuild, cam with stage 3 head, spare box you know any one who needs any bits?
so why do you think its the injectors
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
It Wasnt Me!
Cant be injectors if it runs fine any other time...?
Maybe got a small air leak somewhere that dissapears once its heated up?
I had a prob on my S1 simmilar to what you have, it was a relay that powered the fuel ECU for cold start and on boost fuel enrichment...a small glass fuse was blown in it and it had the same symptoms as you describe but im sure someone said the S2's dont have this relay, it was under the dash next to the fuel pump relay!?
Originally Posted by gup
only happens when cold tho fella
also is your car coming on choke
it should still idle above a 1k when on choke (depends how it was set up)
until it warms then it will let the revs drop try taking the auxirlly (spelling) valve off and clean it up its the little round thing with 2 hard black plastics under the inlet
so how hard is it to change the injectors does the inlet manifold gotta come off as ive got a crome one to put on but was gonna wait till after winter when i rebuild the 1.9
ie it idles higher when cold (on choke)
until it warms up
just a phrase ive always used
until it warms up
s2 you can remove the injecters with only the throttle body to remove thier easy fella just becareful not to twist the fuel pipe when undoing them
also on the auxillry valve if you take it off completely
clean it and put it in the freezer for about 10 mins
the hole should be open if im correct
and when it warms up it will almost close the hole
or it might be the other way round ie
closed when cold and open when hot
It Wasnt Me!
until it warms up
until it warms up
Ah I see you mean on cold start, His wont idle higher when cold thou if he's got the cold start valve disconnected.
IMO it's something to do with either:
Air leak
Fuel ECU
or Setup
will that stop it from starting cause if i un plug the cold start it still takes ages to start
oh oh i might be after some bits
sounds like the injecters are not holding thier pressure over night and the fact that they are about 15 years old![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
regards Tony Turbosystems
because if i undo the cold start its still the same
until it warms up
until it warms up
Air leak
Fuel ECU
or Setup
alright fella i thought the cold valve only works when the engine is cranking tho
until it warms up
until it warms up
Air leak
Fuel ECU
or Setup
the blue cold start injector is not the cold start warm up enrichment .this is controled by your black fuel box and enriches the air fuel charge for cold start and warm up enrichment by controling the fuel pressure actuator on the metering unit and increasing fuel flow through the main fuel injectors.
the blue cold start injector is not the cold start warm up enrichment .this is controled by your black fuel box and enriches the air fuel charge for cold start and warm up enrichment by controling the fuel pressure actuator on the metering unit and increasing fuel flow through the main fuel injectors. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
also have you checked to c if the metering flap is sticking slightly
try removing the a/f and get someone to start it and c if the flap goes down slightly
so if it does not go down is the metering unit shagged?
yes and no really fella ( on it being shagged)
you can adjust these to c if they are just catching the side of the hole
it should stick a bit when hot too unless its just all the shit resting on it over night
well ive got a spare metering unit off that over turb, and a spare fuel ecu in shed and another on the car il change it tmr with the injectors and what else it needs lol
if all else fails il have to build the 1.9 tall block up quicker
try one thing a time fella try the ecu first
but if you change the injecters your gonna have to leave it over night to check to c whats its like in the morning
also rip the plugs out and c what colour thier are too
i wont be out in it tmr night anyway got a 21st party then on sunday gotta go take the brakes and little bits off the over turbo
the shell is fucked and oil pump went and its spun a shell and fucked a rod
i can have what i want for 300 quid everything else is going to scrap yard
got full 1.9 in kitchen in bits hehe
front mount cooler, box paddle clutch, spax suspension what im selling, exhaust whats for sale, all samco hoses all bling under bonnet discs allround, twin head lights what im selling you need owt? just taking whats worth abit little stuff like oil pressure gauges etc
stop messing with all these things fit 4 new injectors un plug the wire from the blue injector and check /reset idle co and base idle.
