Uk supplier for a T3 flange
AET do a GT25 / GT30 flange, so I assume as a GT30 fits a 2wd manifold it would be similar?
http://www.aetturbosonline.com/catal...nge-p-161.html
I would imaging Turbo Dynamics would do them too, as they do various flanges (or did when I enquired last)
Lukesville
Re: Uk supplier for a T3 flange
Originally Posted by Chip-3Door
Im after a T3 flange to make a manifold with, seem to be dead easy to find stateside but not so much so over here, would sooner source a UK one though as its less hassle.
Anyone know who sells them?
just made one for me for a t25 flange,
Lukesville
Need it in the next couple of weeks ideally.
I think the GT25/GT30 one shown is a T2 flange, as thats what most GT30's actually come with if they are internally gated (obviously not the ones cossie lads use though!)
I shall text my mate and see if /when he can make this then, what thinkness would you be looking for 10mm 12mm
Originally Posted by Fiecos Dan
i can get items waterjetted.
looking @ £20 - £30 each, matters on material and quanity.
would you require a cad drawing for the part to be cut or would you need the actual part to cad-cam/measure yourself etc?
a hand drawing will be fine, and then it will be put on CAD.
And approx cost?
Its a plenum spacer for a pulsar plenum.
(I can send a plenum gasket as a template)
And approx cost?
thats not a problem,
pm me a rough drawing, and i'll get a price.
The only draw back just like laser cutting, there's a minumum charge, so one off's can be quite dear, but cheap if a few are done at the same time.
They can do 0.5 - 200mm in any material, and the finish is alot better than laser cutting, as there is no heat involved
This is the shape mate (mobile phone for scale)
http://img.photobucket.com/albums/v2...Photo-0115.jpg
If you could PM me an approx price for 1 and for 5 that would be great.
Also for a flat plate the same outline but "solid" so its not just a spacer but a "lid" for it, made of 4mm or so ally.
Originally Posted by JjCoDeX75
Shouldnt this also be moved to Technical Q&A chip?
Cant see I care much either way though as if it does get moved somewhere else, I will still be able to get to it via "view my posts"
What I would like though is for it not to get spammed with irrelevant chat, so in that respect perhaps it WOULD be better away from GD!
