wheelspining cossie
wheelspining cossie
sounds a bit daft but see when nailing it my car has started to do that banging up and down off the mark rather than screeching the tyres to fuck
it sounds/feels like the wheel bouncing up and down in the arch rather than planting 2 black lines??????????????/
ive got a full set of rear polyushes to go on+just fitted new coilovers
whats your views?bushes?
on my old rst tubo it started to do it when i had the tracking done and got decent new tyres on it before it just used to light the tyres up and not really do it.i put it down to a bit more grip or tryes fitting for grip more as handle as still ok so not like a bush and suspension was all new and still took a beating everyday so didnt seem to be clutch or diff or gearbox as id have thougt they would have destroyed themselves if it was?
maybe you just got more grip now too
i know it probably sounds stupid but thats only thing i could explain it on the turbo.and it deffo had much more grip in dry and the wet i know its totally different on a rwd car so who knows?
who set up your coilovers anyway.was it just your mechanic?or you had it to clcm
Originally Posted by Stu.H
oh and also tried it in the snow
also got the dampers set quite soft for a long drive
My saph used to do this !
Chucked a diff out the rear cos it aswell !
I'd go wit the dampers too, cos I stiffened mine up on the rear & checked the tyres (one tyre was almost flat ) & she was fine after that !
Get the bushes fitted too !
jb
jb
Check the rear diff mount bush, if it's fucked, the diff will rock back and forth in the rubber. This is what the poly diff mounts are for .
Not that i'd do that ! (any more ! but it did work ! )
jb
just to add..dont fit polybushes to the rear arms....you might think you are doing upgradings but you will be doing downgradings
standard ford spherical bearings only for rear arms
Originally Posted by rallyeweezle
Why use spherical bearings? whats wrong with poly?
Dan
Dan
polybushes are ok for some applications...just not cosworth rear arms
Dan
Dan
Dan
Originally Posted by col cos1
are these the big rear bushes that are a cunt to fit anyway
Originally Posted by cossie604
or...use the right tool....altho tbh I bet you cant even buy them now can you?
where u get these from chap as mine bangs sometimes
