MOT - Testers or Mondeo help
My TDCI has failed its MOT on an oil leak
now im sure that there is a quantified number stated in the guidlines in mm cubed that the car has to leak in a period of time
are there any MOT testers who know what it is
as for the mondeo its leaking slightly and its eminating from the o/s area by the wishbone driveshaft , its dripping down onto the subframe , any ideas ?
the bloke who has failed it doesnt know where its coming from ,
I am a current MOT tester !
Oil contamination on brake discs is a failure item (but you have not mentioned oil on discs !) so what the tester should have done is aborted test due to :-
"vehicle being presented in a condition not allowing said vehicle to be checked correctly"
ie, oily and dirty
Steam clean it off and try again if thats all it failed on !
ie, oily and dirty
Originally Posted by MikeyXR2i
Sounds like the guy couldn't be arsed looking!
Imagine if during a test the VOSA/MOT tester says you have an oil leak from head gasket
Owner then replaces head gasket and oil still leaks because it was from somewhere else !!!!!
VOSA can insist that the MOT station refunds or reimburse the owner for mis-diagnosis
During MOT test a tester can/will only pass an opinion on ANY items/faults found at time of test - nothing more !
A garage charging £50 - £60 - £70 per hour etc for diagnosis is a different matter
ie, oily and dirty
ie, oily and dirty
the oil must then be adversely affecting the braking/steering. get the oil leak fixed, end of,
of course its a taxi and most taxi drivers i know are poor
Originally Posted by StuarTurbo
Went under it for 45 minuites with a pressure washer and waterproof suit , cleaned EVERYTHIN , still failed
wowk
30-03-2021 07:49 PM
