what front brake conversions can be used on mk3 escort?
im after a good set up, i.e cossie, heard you can use mondeo st24 etc? ideally after 4 pots of which are easily modded? cheers
2wd cossie four pots will go nut youll need a bracket and the hubs machined to take the bolts. id go with that and some 300m disks (ive got hi spec 300m kit on mines with standard calipers and its quite good but the 4 pots would set it off a treat mate
