fixit or mullit box
#81
Originally Posted by Kelv
Marco, what will be the benefit of having the uprated centre VC set to 60nm?
and then add that to what we spoke about for the rear diff, would it affect the way the car drove atall in any way?
Ta.
Ta.
and no 60Nm VC wouldn't effect the way the car drove at all in anyway
if the VC was set to 90Nm or above would cause the car to push on ..on the tarmac /track would be ok on gravel tho
marco
#82
for mine, would I need to do anything to the front and rear diffs for 460 BHP too?? I know the front diff is the weak part but would a strengthening plate do or would I need to go ATB and thick wall?
Wish I could find a copy of Fast Ford somewhere but no-one has it
#83
Rally nut
#85
Not welcome...
#86
what he offers for the rear diffs 7" or 7.5" 9"
he uprates the planet gears and uprates the VC to 120Nm on the 7" (4wd) and 240Nm on the 7.52wd diff still the weak point is the crownwheel and pionion he offers shot peening and polishing extra cost
for the 9" the VC is massive and can be uprated to 900Nm
but for tarmac the best setting is 520+Nm
there are also lots of different ratios for these diffs right from 3.1 to 5.2
as for the front diff you could buy a thick wall casing and use a strenthing plate and have the crown wheel and pinion shot peened and polish that would make it lot more reliable than the standard unit
cheers marco
#87
How much would it cost to rebuild and upgrade VC LSD of a 7,5" diff?
If you upgrade this VC, I would think that the internal heat-buildup becomes even greater? To my expirience that is what destroy theese units. Should extra cooling be added aswell?
#88
Mullit for me, been excellent all year.
whats the interest out there in a Mullit box with shorter 1st gear?
say from 3.62:1 to 2.6:1.
cheers
Kenny.
cheers
Kenny.
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
