failed on c/o
failed on c/o
hi all, got my evo3 mot this morn and it failed on c/o should be 0.30 and is 1.72%
now iv just rebuilt the engine and have only done 300 miles and the guy says it might just need miles on the clock? how is the c/o altered can any garage do this job? and why would it be high just cus of a rebuild?
thanks
andy
thanks
andy
this is what mlr have said
get a wideband meter on it to check a/f ratio
check fuel regulator psi = 38 to 41psi
check/ replace lambda sensor
all the above should be done in conjunction with each other if possible
andy
andy
just abit more info on this.. for peeps
Cut off date is that it must have been first registered in Japan prior to 31st July 1995 IIRC - this means some EVOIIIs sneak in to the "no cat" test, some don't (although all EVOI and IIs do).
mine was registered on the 31/03/1995
andy
andy
SMILER258
28-09-2015 09:04 AM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
