tyre pressures. whats in your tyres
both front tyres are starting to wear on the inside.so took the car to a Wheel alignment garage yesterday..
so car goes up on the ramps. all details logged into there computer and the bloke says to me.what pressure do you put into your tyres ????
30psi i reply..and he says its not enough
and throws 40psi in each wheel try that he says..the car setups slightly out he said but use 40psi till you get a new set of tyres then come back to me..
i was there about 3/4 hour he never tried to sell me any tyres and never charged me a penny
THAT MAKES A CHANGE
the car felt ok on A and B roads but a soon as i got onto the motorway the car felt really Skitish ..so i stopped at the first service station and lowered back down to 30 psi..and the car felt stable again
Eagle F1 215/40/17 Y all round and its a coss4*4
ps.its not a backstreet garage bloke knows his stuff & got all the latest equipment..just carnt understand WHY SO HIGH PSI 40![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
IDEAS ???
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
IDEAS ???
ideal 40 psi will kill your tyres quicker then you will go back and buy new ones sounds like he does
![](https://img.photobucket.com/albums/v291/sooty52002/LEGION/wa.jpg)
We currently use the Hunter DSP 600 4 wheel aligner with the extended lift.
As you can see on the above picture, targets are placed on each wheel of the motor vehicle.
Your vehicle specs then get placed in the computer and measurements are then done by cameras to find out what the wheel alignment reading on your vehicle is.
Remember that 4 wheel alignment is there to bring your car back to manufacturing specifications.
Adjustments are then made , and you will receive a before and after printout when all work has been completed.
Guest
Posts: n/a
Good results but the fat bloke is a bit of a cock.
and yes they do sell tyres
At a guess running 40psi will slow the wear rate on the inside of your tyres as they're over inflated and the inner edge might not be touching the road anymore.
Originally Posted by Fast Guy
At a guess running 40psi will slow the wear rate on the inside of your tyres as they're over inflated and the inner edge might not be touching the road anymore. ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
bloke seemed to know his stuff though.will be going back when new skins are on the car
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Guest
Posts: n/a
07-10-2015 12:56 PM
