Electrical help needed-foreign plug into UK
Old Oct 30, 2007 | 07:38 PM
MATCOS's Avatar
MATCOS
Default Electrical help needed-foreign plug into UK
I have just bought a new radio for the bathroom ceiling (really) and it has a spannish plug attached (2 prong), can somebody let me know how I wire this into a UK plug or directly into a junction box in the loft please as I don't want to blow myself up!!!
Thanks
Old Oct 30, 2007 | 07:48 PM
St3V3_C's Avatar
St3V3_C
If you don't know what you are doing, stay away from wiring it in permanent.
Cut the plug off and fit one of ours.
One thing though, does it say what voltage (V) it is anywhere?
Old Oct 30, 2007 | 09:45 PM
MATCOS's Avatar
MATCOS
Thanks It is 230v
what about the difference in number of wires as our plugs have 3 and this has 2?
Old Oct 30, 2007 | 10:44 PM
scruffythefirst's Avatar
scruffythefirst
You want to wire a radio to the mains permanently and keep in in a bathroom? Are you mad?
Old Oct 30, 2007 | 10:50 PM
Gaz 88's Avatar
Gaz 88
correct mate it sould be selv or lv eg 12v in a bathroom
Old Oct 31, 2007 | 01:04 PM
MATCOS's Avatar
MATCOS
No, maybe I haven't made myself clear
it is a radio/transformer unit that goes in the loft space, speakers go in the ceiling and it is worked by a remote, I am not going to bodge a radio into a socket and have it draped over the bath
Old Oct 31, 2007 | 01:08 PM
Thrush's Avatar
Thrush
Irritating c........
Why not just fit an adapter plug socket to it - you like, a travel plug thing? Get em in Tesco for about 30p
Old Oct 31, 2007 | 01:12 PM
MATCOS's Avatar
MATCOS
I did think that but would rather do it as well as I can and not use one if I can help it.
Old Oct 31, 2007 | 01:19 PM
ballin's Avatar
ballin
I really shouldn't jump on your thread but I have a quick question!!!
I got confused whilst in Spain about UK > Spanish adapters.
If you plug your UK 3pin socket into an adapter, you can put the adapter into the wall either way round, as its just 2pins.
How does this work?!
Doesn't that mean that you could be connecting positive to negative, or positive to positive depending on which way you plug it in??!
I'm sure there was nothing to stop me turning it around, yet I cant see how this works.
Sorry for butting in but I couldnt find anything on google
Old Oct 31, 2007 | 01:29 PM
St3V3_C's Avatar
St3V3_C
Mains is AC (Alternating Current) this means the positive / negative swap. This happens 50 times a second here - that's why you see stuff mention 50Hz.
Old Oct 31, 2007 | 02:17 PM
Thrush's Avatar
Thrush
Which reminds me of one of the things that makes me laugh - when I hear americans saying "plug this into the AC for me please"
Dunno why, but that makes me laugh LOL.... Over here we would say "plug this into the power" or simply "plug this in" but they often seem to say "plug it into the ac".... Makes me chuckle for some reason
Old Oct 31, 2007 | 03:56 PM
richj's Avatar
richj
In USA they use both AC & DC in there installations
Old Oct 31, 2007 | 04:01 PM
ballin's Avatar
ballin
cheers, always wondered that
Old Oct 31, 2007 | 04:04 PM
-J-'s Avatar
-J-
Best Way - http://www.euronetwork.co.uk/acatalog/Euro_to_UK.html
Old Oct 31, 2007 | 05:10 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
In fact, you can make it really simple for yourself, forget adapters, etc...
Use an piece of plastic (pretty strong) to push down into the earth "hole" in the uk plug socket, then simply push the spanish plug into the remaining two holes of your socket and it will work just fine.
You need to press the earth thing to release the safety mechanism that's in the uk socket, it's a pretty tight fit, but it works fine as long as you don't need to pull the thing in and out of the socket on a regular basis
PS: I will take absolutely NO responsibility if you electrocute yourself.
Old Oct 31, 2007 | 07:53 PM
MATCOS's Avatar
MATCOS
Originally Posted by -J-
Thats a good little idea
Cheers to all for your help
Old Nov 1, 2007 | 08:08 AM
richj's Avatar
richj
Just cut the plug off and put a standard UK one on, job done!
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
