4x4 7.5" rear diff conversion
Has anyone used a 2wd rear 7.5" diff on a std 4x4 drivetrain? I'm looking to swap mine to a 7.5" one but I'm quite worried about killing the centre VC, IIRC the 4x4 stuff is 3.64:1 and the 2wd is 3.62:1?
no the 2wd is 3.64 and 4x4 is 3.62
cheers
Originally Posted by marco polo
Originally Posted by kaliber cossie
i run it on my car no problems ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Hi Steve
didn't you cook the Vc at Spa ???because of the ratio ?
marco
changed the clutch as well as recomended
well I have a spare 2wd back end sat here, I am considering swapping the lot over, just don't want to kill my brand new VC
Do you have to use the 2wd hubs as well or will the 2wd drive shafts fit the 4x4 rear hub?
I think the hub/bearing carrier is the same.
You would however need the outer section of CV/Stub, as this is a larger diameter on the 2wd, same as the diff output flanges.
Hi Steve
marco
hi steve
oh thats cool i stoped will going this route because of your center VC
Will just go the the 7.5 diff then
cheers marco
Do you have to use the 2wd hubs as well or will the 2wd drive shafts fit the 4x4 rear hub?![Top](https://passionford.com/forum/images/smilies/smile011.gif)
will all you have to do is put the 2wd beam on your 4wd everything esle will fit no need to change hubs ect
the 2wd shafts will go in to your 4wd hubs no probs
I know martin used 2wd diff in his mondeo and he never cooked the center vc either
marco
Resident Wrestling Legend
just swap the whole beam over
all you need to do is keep the calipers and discs from the 4wd car, but you'll still have to sort the bleeding out
everything just bolts directly in, just make sure you remember that the prop is offset on the bolt pattern otherwise you'll be tearing your hair out (like me) when it don't line up
will i am in the process of fitting my escort with the 2wd kit!!! i got a ahmed spec 2wd beam 2wd shafts and diff going on with my ring suspension in the next few weeks.. So yes will all fit and work with no problem
prop offset on the bolt pattern? Like the flywheel to crank you mean? ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![tiff](https://passionford.com/forum/images/smilies/punchballs.gif)
Monte Geek
I researched this a lot. The easiest and cheapest way is to use a 2wd beam and a Granada 7.5 LSD diff as it has the 4x4 output flanges and you can buy those diffs for peanuts (mine was £30 odd quid!) Me and Bernie measured up the standard 4x4 7" diff and a Granda 7.5" diff and the output flanges are identical in terms of size and distance between them and position in the two beams
I however i'm not following this route thou
and bought a 2wd Quaife rear diff with the larger Quaife output flanges (so i'm using the larger 2wd shafts aswell) which is at Bernies at the moment being rebuilt into a V6 case and having a shoot peened and polished 3.9 CWP. So the box has gotta come out and go back to DPE for the drop down
but the lsd versions have different outplut flanges to the non led versions ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
so if you are going to put a non lsd diff in you need to be aware of that
also, there are 3 different lengths of driveshaft to consider into the equation as well, being 20.5 inches, 20 inches and 18.5 inches due to the difference of the diff width (something that was denied by others up until they were forced to admit it when they reported it as a discovery they had made after rubbishing my findings about 6 months earlier)
just so that you are aware![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
from what i can remember, the shorter shaft was the one on the drivers side, but i don't have pics on this computer so i shall try and get them sorted for tomorrow evening
Monte Geek
my diff and shafts came off the same car and the shafts are the same length... its all away being repainted and regreased etc atm awaiting my adj beam...
atm
01-09-2015 04:56 PM
xr4x4rs
06-08-2015 09:03 PM
