ms office boffin help required
how do i stop someone from changing a document i've got written in word?
i've got as far as being able to protect document but then it says:
tracked changes
comments
forms
then it says password optional
so how do i do it?
it's different on this set up to what i'm used to as i used to be able to just turn it into a read only file
tracked changes
comments
forms
so how do i do it?
In MS Word 2003, click on TOOLS, PROTECT DOCUMENT (you may have to unfold the pull-down to see this.
A box appears on the right hand side.
In Option 2, select Everyone, then click START ENFORCING.
You will be asked for a password and the job is done.
Alternatively go into tools, options, security and whack a password into the "modify" box, reenter it and remember to save it and its done.
you've got a much later version then
i'm on the wrong computer to open it up though as this one hasn't got word on it but the other one has so i'll see if i've got a different version at the other house
let you know tomorrow and cheers for all the help so far
Just booted up a REALLY old laptop (so old that the battery doesn't work!) and tried it in Word 97
Select FORMS, add a password and that's that.
I don't have anything any older to check for you, but hope this does what you need.
Alternatively, if you go to the Adobe website, you can convert a number of documents to pdf each day without downloading anything.
wowk
30-03-2021 07:49 PM
