a little help please
the story is, i have been offered a complete 2wd engine, the spec is green injectors, cams ? but they have adjustable cam wheels, a T35 turbo, breathers from block and cam cover, running 21psi, swedish style inlet
need to go 4wd for my race car so
1) will a 4wd sump fit the 2wd block
2)2wd flywheel compatable with 4wd mt75 box
3)will a dohc mt75 gearbox fot the 2wd cossie engine (already in car)
4)can use existing xr4x4 driveshafts at the front
thanks Neil
thanks Neil
Lambchop
where are you as the owner of the engine is near aberdeen running it a space frame pug 205
xr4x4rs
wasnt sure but can the dohc box take the bigger clutch as it uses the 215mm size and the cossie is 241mm
was told by another competitor that the oil pick up pipes are the same it's only the pumps that are different, will need an oil pick up pipe anyhow as the sump was shortened to fit the spaceframe
xr4x4rs
so i need the following
4x4 sump
oil pick up pipe
4x4 flywheel
4x4 engine arm mounts
4x4 mt75 clutch arm to use my own gearbox
and the front diff and cross shaft from my dohc box will fit the cossie 4x4 sump
4x4 sump
oil pick up pipe
4x4 flywheel
