fuel pump voltage now with new readings 7/10 !
Old 06-10-2007, 07:19 PM
mechanic28
mechanic28's Avatar
Default fuel pump voltage now with new readings 7/10 !
ok peeps finished fitting my group A fuel pump and re-wire but not 100% happy i have got 13.9 volts at the battery but 12.8 at the pump drops to 12.6 when cooling fan on etc? earth has been fed straight back to battery so cant be a earth probs!would u expect this voltage difference?forgot it on a 2wd sapp cossie
Old 06-10-2007, 07:32 PM
mechanic28
mechanic28's Avatar
upp
Old 06-10-2007, 07:39 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Go and test it at peak boost and high revs mate...
Old 06-10-2007, 07:41 PM
bud-weis
Football Cwazy
bud-weis's Avatar
i'd say that was quite good compared to most cossies
i rewired mine in the week, it was 13.6v at the battery, but 9v at the pump
it's now about 12.9v at pump, although i haven't checked it on boost yet
Old 06-10-2007, 07:43 PM
KSA-Cossie
KSA-Cossie's Avatar
I have 14.2v at battery,14v at secs monitor and 13.9v at pump.
Old 06-10-2007, 07:45 PM
mechanic28
mechanic28's Avatar
cool i thought it was quite low would not expect to loose a volt could abit difficult to check voltage under load leads not long enough stu so u think 12.8 at idle is ok when volta at battery is 13.9?
bud-weis 9v jesus thats low
Old 06-10-2007, 07:46 PM
mechanic28
mechanic28's Avatar
thats what i am thinkin was expecting around the 13.4 at the pump mark
Old 06-10-2007, 07:48 PM
KSA-Cossie
KSA-Cossie's Avatar
What size cable did you use i used 10mm
bud-weis
Football Cwazy
bud-weis's Avatar
i know
luckily it's never seen full boost in my ownership
Old 06-10-2007, 07:52 PM
mechanic28
mechanic28's Avatar
as bad as it sounds cant remember it was good for 27.8 amps tho
Old 06-10-2007, 07:54 PM
mechanic28
mechanic28's Avatar
i know
good job as well fella
Old 06-10-2007, 08:11 PM
mechanic28
mechanic28's Avatar
who else has done a re wire on the fuel pump and what voltage did u get
Old 06-10-2007, 08:31 PM
Neil S
Neil S's Avatar
I'd expect your voltage to be higher at the pump than you've measured. If all your wiring is new then all being well I'd expect your voltage to be higher.
Did you wire it as described in our PM's?
Neil.
PS If I recall, my wiring drops 0.1V from pump to battery. (i.e. I have .1V less when measuring at the pump compared to across the battery)
Old 06-10-2007, 08:46 PM
mechanic28
mechanic28's Avatar
yer the same way fella bit mythed to be honest not happy just want it all right before i get it live mapped can not figure out y i have lost over a volt might take off all the connectors which i soldered and put some new one in and crimp them instead
Old 06-10-2007, 08:49 PM
Neil S
Neil S's Avatar
So it's as per mine only with a direct earth back to the battery?
Do you have any idea what current is flowing in the circuit?
Old 06-10-2007, 08:50 PM
rssteve
rssteve's Avatar
if your cable is only rated for about 27A then i would guessyou have used 2.5mm2 cable. you really need to know the exact cable size as it sounds like the cable may just be suffering from abit of volt drop.
Old 06-10-2007, 08:53 PM
mechanic28
mechanic28's Avatar
yep fella live taken after the cut off switch for the switching circuit of the relay original earth of pump for earthing of the switch circuit brand new wire to and from batt to pump,no aint got a clue bout who much current is going throu how u check this?
Old 06-10-2007, 08:57 PM
mechanic28
mechanic28's Avatar
just checked it 3mm cable but 27 amp wiring should easy cope with the fuel pump pull
Old 06-10-2007, 09:00 PM
Butch.
Butch.'s Avatar
i have rewired a customers 3 door today and it shows 13.9 at battery and 13.5 at the pump which i was happy with
Neil S
Neil S's Avatar
You would set your meter up to measure current and put it in series with the pump.
Something is amiss somewhere by the sounds of it
Neil.
Old 06-10-2007, 09:07 PM
mechanic28
mechanic28's Avatar
yes i agree think i will see how many volts are at termimal 30 of the
relay tomorrow see wot the volts is there! me not happy
although on the plus side it is above 12 volts
Old 06-10-2007, 09:31 PM
rssteve
rssteve's Avatar
im not suprised its so low. Not a bad guess was it 2.5mm2. Not big enough tbh it might have a rating of 27A but when you add lenght you get volt drop. not sure what a fuel pump draws but id put in a 6mm minimun to decrease the resistance of the cable. or you could run a couple of your 3mm2 in this will halve the resistance so less voltdrop.
Old 06-10-2007, 09:39 PM
mechanic28
mechanic28's Avatar
can understand where your coming from fella but i dont think this is the problem out of interest if this voltage ok ?or to low in your opinion?
Old 06-10-2007, 09:55 PM
Karl
Norris Motorsport
Karl's Avatar
Pump should be earthed to the chassis using as short an earth cable as possible, and not returned to the battery via a cable. (Unless I mis-understand what you wrote above)
Old 06-10-2007, 10:07 PM
mechanic28
mechanic28's Avatar
ok just checked got 13.4 volts at terminal 87 of the relay using the original fuel pump earth so can only be 2 things 1 bad connection in the wire from term 87 to pump or voltage drop due to running my earth all the way back to my battery wot u think?
Old 06-10-2007, 10:44 PM
Karl
Norris Motorsport
Karl's Avatar
Earth the pump at the chassis next to the pump. Running back to the battery will cause a significant voltage loss.
Old 06-10-2007, 11:04 PM
mechanic28
mechanic28's Avatar
earth it where?anyone have any pics?
Old 06-10-2007, 11:06 PM
Karl
Norris Motorsport
Karl's Avatar
Anywhere suitable as close as possible. We normally use one of the anti-roll bar clamp bolts with a suitable eyelet to earth the cable.
Old 06-10-2007, 11:18 PM
rssteve
rssteve's Avatar
its fine to use the cable as the earth providing its big enough. the earth of the body work is only as good as the small earth strap thats go from body to battery(neg terminal) and remember these also have to take all other power back from other electrical bits. If you got some spare 3mm2 cable run another and join them together. thus giving 6mm2 cable this will make the volt drop alot less. For the size of cable the voltage you are getting at the pump currently is what i'd expect.
Old 07-10-2007, 06:08 AM
Wardy257
Wardy257's Avatar
You need to volt drop it all properly. Test the voltage between the pump negative and a good earth on the body. Volt drop each side of the relay, volt drop everywhere!!!!! Simple checking the voltage between the pump positive and earth is an almost meaningless figure as it wont tell you if, and where you are losing the voltage.
Old 07-10-2007, 07:13 AM
I like some of the theories here!!
Cable too small, resistance of copper wire is 0.000999 OHMS per foot@20Celcius.
Group a pump draws max 13amps@12 volts, so cable carrying capacity of 27 amps not big enough!!
For all people use the formula,
R=pL/A.
If you want to go even more overboard use Silver wire as resistance is only 0.000944 Ohms/foot.
I assume you used thinwall wire(?), as 44/030 will carry 27.5amps continuous.
This is 3mm(2) which is almost the same as 12 gauge.
over 30 feet, or 9.1440 metres, at 13 amps and 77F this wire will drop 0.6318 volts.
As you can see this is more than capable of the task in hand, so you have to look elsewhere.
Solder can build a resistance, did you use PURE silver solder, or with ROSIN(flux), or std 60/40 lead tin ?
Old 07-10-2007, 12:12 PM
PGT
PGT's Avatar
as tabetha says 3mm plenty thick enough. one way forward is to wire a 100watt headlamp bulb in parallel with fuel pump to simulate the current draw at full boost and allow you to establish voltage at the pump under actual road conditions. it will also make it easier to find where the problem is. my money is on tired relay / old connectors
Old 07-10-2007, 02:57 PM
mechanic28
mechanic28's Avatar
hmm ok here is wot i have done today routed another earth to where karl suggested (cheers fella) now reads 13.1 volts so better stll think it might be the soldering pulling it down abit might tke them off and crimp them??
Old 07-10-2007, 03:31 PM
MAD Ade
MAD Ade's Avatar
R=pL/A.
Tabatha,
do you mean 44/0.30 as 44/.030 will give you 0.0311mm2.
Old 07-10-2007, 04:04 PM
mechanic28
mechanic28's Avatar
R=pL/A.
no fella used standard cable
Old 07-10-2007, 04:12 PM
Received 1,044 Likes on 998 Posts
I just drilled a hole in my spare wheel well for the earth and used a nut and bolt. I put a new live wire from the original fuel pump relay to the pump.
Old 07-10-2007, 05:22 PM
JamesH
JamesH's Avatar
Same!!
It's used to earth something else in my boot too!
Old 07-10-2007, 05:37 PM
mechanic28
mechanic28's Avatar
Same!!
wot volts did u get at your pump?mines up too 13.1 now
Old 07-10-2007, 05:45 PM
SteveB
SteveB's Avatar
I'm sure others are wondering this as well....
I'm going to rewire mine over winter...... now how do ya do it with an idiots guide...lol (I'm ok with the earthing bit)
Is it a case of from the battery to the std relay then onto the pump or more complicated than that??
Steve
Old 07-10-2007, 05:48 PM
scoooby slayer
scoooby slayer's Avatar
ive got 14.3 at the battery and 13.3 at the pump and it was checked and mapped like that by stu at msd and he was happy so must be ok.
Quick Reply: fuel pump voltage now with new readings 7/10 !
